Old 10-29-2004, 07:24 PM
sendkeys is on a distinguished road
Anyone Know a know of a good book for mill, tool making?
Hello everyone
Does anyone know a good book for making mill tools. Making engraving bits, sharpening endmills, even making your own endmills and any other mill tool
Old 11-01-2004, 03:31 AM
i guess no one reads anymore hehe
thanks anyway
Old 11-01-2004, 06:36 PM
scottsss is on a distinguished road
What type of milling and tool making? It is a very broad subject. I've only made a fixture or two and a few otehr little tools. I'll help if I can.
Old 11-01-2004, 09:46 PM
hiya Scottsss
Mostly trying to find something on engraving bits, endmill sharpening. cutting tools. not really fixtures. Just trying to come up with some idea's to save money on tooling. I have access to a surface grinder,heat treating kiln ect. i know the basic idea for simple stuff like "d-bit" but be nice to see a book on other tools. maybe come up with a better way of making them.
Main problem is i dont think there is a book on this subject hehe. Maybe just parts here and there inside other books. Been hunting Amazon for week or so now havnt seen much in the line of "cutting tool making"
Thanks Scottsss
Old 11-01-2004, 10:05 PM
Machinery's Handbook has a section on that. You can also check out their other books. http://www.industrialpress.com/en/index.asp
Old 11-01-2004, 10:15 PM
HuFlungDung's Avatar
Moderator
Scott,
This is a pretty specialized field and requires a lot of special equipment and processes. I would imagine if you went to purchase a cnc tool grinder, that it might have a lot of the necessary functions built into the operation manual.
First off, you need to learn about helical milling processes. This is the gearing action required to make a form cutter cut a helical path in the tool blank, to form the flute of the cutter. Various helix angles are required for different cutters specifically for certain metals.
A lot of high quality tools are made now, ground from solid hardened material. This means a cnc tool grinder creates the tool from start to finish. The blank could be high speed steel or carbide. Perhaps even a carbide preform, which would be easier to grind than carbide that has been sintered (final bonding to convert it from a pressed powder to "real metal" ).
Then, you need to learn about clearance angles to make a tool cut properly. This information is available in manuals that come with milling cutter resharpeners.
Other cutters, called form-relieved cutters are used for various milling processes, like gear cutting, etc. These require special lathes that can repeatedly push the tool into the toolblank, while it is rotating, to "back off" (create cutting clearance) for each tooth of a multi-tooth, wheel type cutter.
Its a big field when it comes time to buy the machinery to do it all.
Old 11-01-2004, 10:56 PM
Scotts i have a real old copy of the "Machinery's Handbook" that i picked up at a yard sale. You might be right think i will go down to the tech bookstore here in town i was told about and will check out see what's in the new version Thanks for the idea
Hiya HuFlungDung
Cnc grinder is a idea... Will have to look into that some more. I can check out there manuals online that's a very good idea
Thanks guys for the help at least i have somthing to try i was almost going to give up and just go back to what i was doing befor
What is high speed machining Klox Hard and High Speed Machining 111 01-26-2011 01:21 PM
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 05:24 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Here's some good information on making work holddown vacuum pods buscht DIY-CNC Router Table Machines 6 01-31-2005 01:22 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
