Old 10-23-2008, 07:15 AM
mthompson is on a distinguished road
Question Process controls for Precision Machining
Would anyone have any case studies or information for process controls for precision machining. We have applications were the tolerances are +/-.0003", but there are no different controls than cutting to +/-.010". As a result we have higher scrap for those parts with tighter tolerances.
I would be interested in any info you may have. I have read a bit on thermal error. I have read on thermal error compensation and also temperature control of hydraulic oil and coolant. Any success stories on retrofitting existing equipment for thermal control would be of special interest along with specific maintenance requirements.
Thanks!
Old 10-26-2008, 04:09 PM
*Registered User*
Bluesman is on a distinguished road
What are you machining, And what are you holding. Dia? Flatness? roundness? Profile??. That make a huge diference I have aluminum housiongs that I hold flatness to .009mic and roundness to .009. Also some tight bore tolernces.
Bluesman
design and machining process project5k Mechanical Calculations/Engineering Design 17 08-07-2007 09:16 AM
machining of polymide coated rollers by hobbing process rvrdom07 General Metalwork Discussion 1 01-22-2007 01:33 AM
2 highly skilled brothers in a small shop available for immediate precision machining Chipbreaker Employment Opportunity 1 11-20-2006 11:47 AM
What kind of process controls does MC have? HuFlungDung Mastercam 3 05-28-2003 10:31 PM
