Old 10-21-2008, 11:36 AM
keith_k98 is on a distinguished road
What's the best coolant/lubricant????
Hi, I would like to know what you guys use for coolant?
I'm fairly new to the machining process. I have an x2 mini mill and a 7x10 lathe. I use HSS tooling. Right now I use a spray bottle to mist the part I'm working on but I am in the process of converting over to flood coolant . The coolant I am using is Kool mist 77 from the Littlemachineshop
The problem I'm having is that with the Kool mist is rusting the parts & my machines even at doubling or slightly over the recommendation on the bottle of concentrate.
any suggestions for a good coolant & where to get it will be appreciated.
Old 10-21-2008, 03:35 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
TriCool makes nice coolants that are enviromentally friendly, won't cause skin rash's, smell like a dead rat or cause flash rusting. That's what I use, and a little PineSol will make it smell a little better. I don't notice a smell at all, but my friends say it has a slight odor (of shop oil) which is nothing compared to some of the other coolants used at other shops I've worked for. You almost gag monday morning when you walk in after a full weekend of fresh air!
Old 10-21-2008, 08:19 PM
Hey, mc-motorsports thanks. Is TriCool an oil based coolant? wheres a good place to buy it?
Thanks!
Old 10-22-2008, 02:33 AM
Yes, it's oil based, I think they also make a vegtable based coolant also but it's expensive. Anyway, I get it from JTS, they have a website JTSMACH.com but they are local for me. Grainger also sells it, more than likely McMaster Carr would carry it too. Common stuff.
Old 10-22-2008, 07:44 AM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
Here we machine all different types of metals in short runs, there's an even bigger machine shop where I work and we use what they recommended. It's called Hocut-795, It's a lil pricey but I haven't come across any rusting issues yet.
Also I'd recommend Liquid Ice Coolant, they'll even send you a free sample. The water here is real harsh and the Hocut wasn't mixing that well for whatever reason, literally over night the emulsion was breaking up. I mixed up Liquid Ice though and it has stayed suspended in a stagnant dish for over 3 weeks now.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
Old 10-23-2008, 08:05 AM
ksimmons is on a distinguished road
I've used Blaser 4000 strong in saws, mills, and lathes with excellent results. I've never had any skin or smell issues. We cut mild, stainless, and aluminum and don't change anything in between, other than cleaning out chips. It is supposed to be environmentally friendly. I've never had any issues with rust while using this stuff.
Tags
coolant, lubricant, mini lathe, mini mill
Lead Screw Lubricant sdantonio Linear and Rotary Motion 2 05-11-2010 07:38 AM
IH head lubricant Runner4404spd Industrial Hobbies (Support forum) 14 01-29-2008 09:41 PM
Dexron used as lubricant? ranchak Benchtop Machines 13 11-25-2007 02:28 PM
Lubricant for ways ranchak Benchtop Machines 4 11-24-2007 09:08 AM
Lubricant joecnc2006 Mechanical Calculations/Engineering Design 0 11-26-2005 01:35 AM
