Old 10-21-2008, 02:08 AM
boxmaker is on a distinguished road
Getting a brass logo machined
HI Everyone
I'm new to the forum and I hope I have this in the right place. Can anyone mill a logo for me out of 2mm brass? The logo is the letter T and is to be silver plated. It is to be inlayed into the lid of a corprate box which I am going to make. I would like a small chamfer around the top of the T as I want to inlay it into the box down to the chamfer so that the actual T sits slightly raised above the surface.
I have attached an image for anyone interested. The T dimensions will need to be 45mm high x 51mm wide.
I'm in the UK.
cheers
Ian
Name:	Tolkowsky Logo Outline LOW RES.jpg‎
Old 10-21-2008, 03:21 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Ian,
Some one in the U.K. should respond pretty quick.
Welcome to the zone.
Jeff...
Name:	3D View.jpg‎
ID:	68273   Click image for larger version
Name:	3D View Front.jpg‎
ID:	68274   Click image for larger version
Name:	3D View .25 Edge.jpg‎
Old 10-21-2008, 03:28 AM
Thanks Jeff
Wow thats looking good.
Ian
Old 10-21-2008, 03:35 AM
jalessi's Avatar
Smile
Ian,
Take a look at these routers, they would be able to do all your brass work.
You would need to add your own stepper motors and drives, however they are very precise.
http://www.widgitmaster.com/
Jeff...
Old 10-21-2008, 03:58 AM
Hi Jeff
I was hoping for someone to mill this for me as my main area of work is woodworking and although I would like to get into the area of milling it is too much of a learning curve at the present time, for instance the link you posted when I looked at it I wasn't even too sure what I was looking at and what it was.
I am a complete novice.
Ian
Old 10-21-2008, 07:22 AM
keebler303 is on a distinguished road
Ian
You need to check out the RFQ (request for quote) forum on cnczone. There you can tell people what you need and they will give you a price. Someone here should be able to help you out.
Matt
Old 10-21-2008, 08:36 AM
Fixittt is on a distinguished road
why not get it machined in wax? Then get it casted in silver? I would think that the casting fee and the plating fee would be about the same and your only looking at about MAX $10 to $20 depending on the size for the silver.
Need A Quote- Logo RFQ Erik W Employment Opportunity 3 08-05-2008 10:16 PM
Newbie- Weld Brass to Brass piratesover40 Welding, Brazing, Soldering, Sealing 3 03-03-2008 06:02 PM
RFQ - Machined logo (DONE) cn00728 Employment Opportunity 4 10-20-2007 05:54 PM
RFQ Logo buckkillr8 Employment Opportunity 17 04-16-2007 11:01 PM
Need help with Logo CRFultz SheetCam 13 05-01-2005 06:23 PM
