Old 10-15-2008, 08:48 AM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
ER-16 Collet not for End Mills?
Hey, My Haas training technician told me that I should use ER-16 Collets for holding drills but not end mills. Can anyone clarify why I shouldn't use ER-16 collets for end mills and does that Mean I shouldn't use ER-32 Collets for End Mills as well or are they ok to use?
-JWB
Old 10-15-2008, 09:16 AM
I no longer use an ER16 collet for a 3/8 end mill taking a good healthy cut; it turns the collet into a helix when the cutter breaks.
For anything smaller there is no reason not to use ER16, and even for 3/8 an ER16 is needed when there is simply not enough room in a fixture or the part for a bigger collet nose.
Old 10-15-2008, 10:29 AM
ckirchen is on a distinguished road
I ran an endmill in an ER-16 collet all day long yesterday. Not sure why the tech would recommend not to. In my opinion, it's perfectly acceptable practice.
Old 10-15-2008, 03:03 PM
scadvice is on a distinguished road
Smile A ER16 Collet's upper limit...
... is about .375. The upper limit...that means you baby it a little at that size.
To me that is a max .006 chip load per tooth on a 3 flt. in alum. as fast a RPM as your machine can handle. 65% engagement and 50% diameter DOC. Climb cut only. Also a stub EM.
Steel .003 per tooth 4 flt. 1800 to 2400 RPM (Dep. on Alloy coated with radius cnrs.). 75% engagement and 33% DOC. Climb cut is best. Stub or standard.
A properly installed cutter in a ER-16 collet will run without problems at those sittings ( With some minor tuning).
ER-16 collets need to be a good brand. There are some out there now that are crap. Material and run-out. The good ones will run very true .0002 tenths one inch out. The only problems I've ever had have been with a ER from India and China. Sorry guys from India...mainland China too.
I will not use them for drilling unless I use a new drill and I stone the lettering down if it is raised. Normally, I do not use them for drilling they cost to much for that.
If you are really trying to push a .375 EM then step up to a ER-20.
My thoughts anyway and that tech has no clue. - Steve
Old 10-16-2008, 07:40 AM
ALLtra Mach is on a distinguished road
I've ran lots of end mills in ER collets.
However, you will not get the performance that you would out of your mills if they were in a more ridgid set up than ER, regardless of size. That boils down to a cost versus production matter.
I won't remark on the Hass part of the equation.
I hate deburring.....
Lets go (insert favorite hobby here)
Old 11-09-2008, 09:11 PM
ktm666 is on a distinguished road
er collets are not the most precise of the bunch. in my opinion shrink fit tooling is the only way to go for solid carbide cutters.
Old 11-09-2008, 09:37 PM
Andre' B is on a distinguished road
These work fine.
http://www.gohpi.com/HPI2007Update0807MX.pdf
Old 11-09-2008, 10:07 PM
I've read that hydraulic holders (such as those from www.schunk-usa.com) rival shrink fit holders.
Chris Kirchen
Old 11-10-2008, 02:48 AM
Astonlee's Avatar
Astonlee is on a distinguished road
ER Collets double their clamping force
There is no reason why you shouldn’t use ER16 double angle collets for milling like most things “if you buy good quality collets” However make that you size for size collet e.g. ER collet have 1mm of collapse, so do not use Ǿ7mm collet for a Ǿ6mm milling cutter otherwise you are asking for trouble. You can double the clamping force of ER collets by using chucks fitted with a “bearing nut”, as it overcome the friction created between collet & nut when tightening, and double the clamping force. This is an editorial link on benefit of using precision collets on tool-life: http://www.mctooling.com/index/listings/page972.htm
Old 11-10-2008, 03:12 AM
Astonlee's Avatar
Do not use shrink fit tooling for solid carbide rippers!
Shrink work brilliantly on all milling application apart from solid carbide ripper cutters. As I use to work for a specialist high-speed/performance cutting tool company. We first starting using/selling shrink-fit over 15 years ago, but kept having mixed results when started applying solid carbide ripper made by a really high-quality Swiss manufacturer.
They kept telling us to only use side-lock, and we kept arguing with them they were wrong, in the end they came over a ran extensive trials using our Mori VMC, but they were right even with shrink-fit you can get micro-slippage of the tool in extreme applications, from then on we only use the ripper in side-locks and never had a problem again using their rippers.
  #11   Ban this user!
Old 11-10-2008, 03:27 AM
Astonlee's Avatar
Info on hydraulic toolholders
Hydraulic holders were designed for use in precision drilling application and their TIR matches that of shrink-fit. They are suitable light to medium milling application, but not for taking heavy side cutting as they will flex, and allow the cutter to push over.
  #12   Ban this user!
Old 11-10-2008, 07:49 PM
enauman is on a distinguished road
ER-16 Vs. Er-16A
Is there a difference between an ER-16 and an ER-16A? I've seen both nomenclatures. Another question: is the bevel in the ER clamping nut supposed to be ground off center?
Need Help!- need a collet RICKDIPLEXERS Haas Mills 2 11-12-2008 08:36 AM
5c collet - serious run out.. pmurdock General Metalwork Discussion 5 05-04-2008 12:33 AM
Need Collet Help opmi General CNC (Mill and Lathe) Control Software (NC) 3 01-26-2007 06:58 PM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 12:35 AM
collet Smackre WoodWorking 3 05-12-2006 06:58 PM
