Old 10-14-2008, 01:27 AM
12six is on a distinguished road
Difference between R8 and Morse Taper Holders
Hello everyone, sorry for the nubie question, but I was looking for a end mill holder to purchase, and just found out that there is a R8 end mill holder with the draw bar size of 7/16" 20 and a Morse Taper end mill holder with draw bar size of 3/8" 16 Wanted to know what the difference in the two holders. End mill holders are for a Harbor Freight 33686 http://www.harborfreight.com/cpi/cta...emnumber=33686
Thanks,
Charles
Old 10-14-2008, 01:54 AM
Splint is on a distinguished road
Thanks,
Charles
R8 is a different design and relies on a drawbar to hold it in the spindle, morse taper is held in the spindle by the friction alone on the tapered surface. I have never seen a R8 work loose while in opperation but have seen morse tapers work loose on many occasions. Dont be put off morse taper by what I have said here but given the choice I would go with R8.
Old 10-14-2008, 02:09 AM
Thanks for the reply. I am using a mt3 chuck, and it is coming off as it is. I guess I can remove the morse taper holder from the list.
Thanks again,
Charles
Old 10-14-2008, 04:23 AM
TOTALLYRC is on a distinguished road
Thanks again,
Charles
Your machine has an R-8 spindle. You can't put a morse taper tool holder into a r-8 spindle and vise versa. To do so will destroy something.
For your machine you will need to buy R-8 tooling only or get a set of R-8 collets if you don't have them already and then you can hold just about anything. A good set of R-8 endmill holders is a nice addition and they will allow you to maintain the same z height every time the tool is removed and reinstalled.
If you are using a chuck, and it is probably has a Jacobs taper, they will come off because it is not designed to be side loaded as in milling but to be vertically loaded as in drilling.
I hope I understood what you were asking and you understand what I said.
Welcome to the wonderful world of machining and remember, we were all nubies once.
P.S. As you saw a morse taper can have a drawbar depending on the machine and tooling will not fall out when it is held in this manner.
Old 10-14-2008, 02:35 PM
OK, that made things alot more clear. Just got the machine a few days ago, thought something was wrong with the spindle, but I guess I have to get the R8 End Mill holders.
Thanks,
Charly
Old 10-14-2008, 09:59 PM
I made the same mistake only a few years ago. Glad to help.
Mike
Old 10-15-2008, 12:09 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
R8 tool holders are much more common, plus you can use collet holders. You may find it's much more expensive to find a morse taper endmill holder, to where as R8 endmill holders are readily available at any tool shop.
MORSE TAPER TO 5C ADAPTOR smallblock General Metal Working Machines 1 08-23-2008 11:25 AM
Difference between CAT50 AND BT50 HOLDERS??? moldmen338 General Metalwork Discussion 1 11-23-2007 02:58 PM
Morse taper studysession DIY-CNC Router Table Machines 1 09-03-2007 06:04 PM
Teflon on 40 taper holders carbidecraters Fadal 18 02-01-2006 12:19 PM
Taper for tool holders? davidmb DIY-CNC Router Table Machines 3 10-16-2005 03:08 PM
