Old 10-13-2008, 08:02 PM
Gene-Yo is on a distinguished road
Large OD Alum or Steel Tube
Does anyone know where to buy a large OD / ID (Outside Diameter / Inside Diameter) tube made of steel or aluminum?
I am trying to locate a tube in two sections that measure around 14" to 18" OD. Tube sections needed are about one foot each and they must match.
Anyone? Must be metal such as steel or aluminum and not plastic or similar materials. Prefer a 1/8" or 1/16" wall or something that is rigid.
Thanks for the help!
Old 10-14-2008, 08:51 AM
ALLtra Mach is on a distinguished road
Boyd, Metals USA, Namasco...that large with thin wall probably special order.
I hate deburring.....
Lets go (insert favorite hobby here)
Old 10-14-2008, 09:44 AM
keebler303 is on a distinguished road
Just go to a sheet metal guy and they can roll you whatever you want. Guess it depends on how round you need it though.
Matt
Old 10-15-2008, 06:53 AM
neilw20's Avatar
neilw20 is on a distinguished road
Skilled person
A skilled person can even roll ROUND tubes.
1/4" or 3/8" is not even a drama with the techniques. Not even a flat bit at the start of the roll.
Just a perfect shape with submerged arc welding from both sides.
Take a look at nicely made gas bottles and compressor tanks as an example.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 10-15-2008, 07:00 AM
TOTALLYRC is on a distinguished road
Go to your local compressed gas or propane supplier and see if you can get an out of date bottle of the correct diameter. They get too old to use as a compressed gas bottle, but maybe it will still work for you.
Bending stainless steel tube, what tool? Sperstad Bending, Forging,Extrusion... 8 12-17-2010 06:11 AM
Large Steel Channels LazyMan DIY-CNC Router Table Machines 2 09-28-2008 07:06 AM
Filling steel tube with cement for damping/mass? stag53 Mechanical Calculations/Engineering Design 6 11-26-2007 01:39 PM
Looking for 2" square steel tube. danmickey DIY-CNC Router Table Machines 3 11-15-2005 05:22 PM
Need recomendations on 2" square steel tube for router frame. danm DIY-CNC Router Table Machines 3 11-14-2005 06:21 PM
