Old 10-10-2008, 02:38 PM
JeffreyCNY is on a distinguished road
Solid Riveting
I need to set solid rivets in a product for production, in a small business. I need to set a 1/8" diameter solid copper rivet. I tried a ball peen hammer, but it isn't great for production. I looked online at squeezers, but the one I was quoted is $1800. I am thinking of trying a 3 ton arbor press. We plan to make 200 products a year.
Does anyone have first hand experience with a squeezer?
Has anyone used an arbor press to set solid rivets?
Does anyone have first hand experience with solid rivets?
Thanks,
Jeffrey
Old 10-10-2008, 03:47 PM
Can you rig-up an air chisel with a rivet forming tool? (small air hammer)
Just a thought.
Dick Z
DZASTR
Old 10-10-2008, 04:18 PM
You should need less than 1000lb to set your rivets so it is well within the range of a small arbor press.
If your rivets are countersunk you don't need anything except flat steel for your dies. If they are domed you will need to make a simple die plate by machining a hemisphere with a ball nose mill and similarly in the end of a piece of steel rod for the top die.
Old 10-10-2008, 07:36 PM
dgapilot is on a distinguished road
I do aluminum rivets on aircraft with a hand squizer or a rivet gun (similar to an air hammer) with rivet sets. Look here for tools for rivets http://www.yardstore.com/
David
Old 10-10-2008, 09:56 PM
little bubba is on a distinguished road
I've done more solid rivets than I care to count, it could have only been two, but still more than I ever wanted to do. But its been a lot.
We have a pedestal mounted air riveter and a handheld air powered riveter for the assemblies that we do that require solid rivets.
As for the arbor press, I've made some fixtures that had to be used on an electric over hydraulic press. The problem there being over or under squishing. With a proper riveter, you can set your squish to get the proper size head, both in height and diameter(proper length rivet of course). If you can set yourself up a stop, you can probably get away with the arbor press.
Check E-bay, thats where we got the hand squisher, $160.
Tags
rivets
What solid cad program? ddrian BobCad-Cam 13 11-04-2007 08:52 PM
Solid To 2d osomaker Mastercam 6 12-27-2006 12:42 AM
DXF to any SOLID dannyboysd89 General CAM Discussion 11 11-18-2005 05:27 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 06:25 AM
Solid cutters HuFlungDung OneCNC 4 04-23-2003 03:41 PM
