Old 10-07-2008, 08:28 PM
RP Designs is on a distinguished road
Measuring splines
Anyone have a good method to measuring splines? I have a small shaft with what appear to be straight splines that I would like to measure. I don't know if they are ANSI, ISO or DIN (most likely ISO since it is european). Any suggestions?
Old 10-07-2008, 11:15 PM
ALLtra Mach is on a distinguished road
What are you trying to measure on them?
the spline itself, the spacing? Diameters?
A set of pin mics works well but takes a trained hand, rotating into the measurement.
Especially in a used shaft, it is easiest to take your readings, then compare them to the standards for the size of shaft.
take all the measurements you can and compare them to find out what shaft you have.
I hate deburring.....
Lets go (insert favorite hobby here)
Old 10-07-2008, 11:33 PM
Unfortunately the splines on the shaft are very small. What I am trying to do is determine the mating splines for the shaft. I don't know which standard it is so it is difficult for me to measure and compare to any given standard. I haven't taken measurements bt the shaft is about 13mm in diameter and has a lot of splines (maybe 70 or 80 splines).
Old 10-10-2008, 09:16 AM
easymike29 is on a distinguished road
You can project the contour onto a shadowgraph with surface illumination. If not, then you can try an eye loupe with reticle graduations. An example.
http://www.edmundoptics.com/onlineca...productID=1860
Gene
Old 10-10-2008, 12:20 PM
beege's Avatar
beege is on a distinguished road
Facsimile compound / optical comparator? Most surface illumination isn't good enough for shapes on the end of a shaft, and you may have difficulty mounting the shaft on the scope.
Old 10-10-2008, 03:49 PM
Got a gear shop nearby? If so, they could probably tell you what it is.
Dick Z
DZASTR
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Where are my splines? PhillyCyberJoe Solidworks 2 01-04-2008 10:59 AM
I can't get rid of splines!! dan3676 General CAM Discussion 1 09-21-2006 09:57 AM
Splines spalm SheetCam 14 02-18-2006 06:26 PM
Splines dneisler General Metalwork Discussion 3 11-30-2005 09:03 PM
Help with splines CNCRob Autodesk Software (Autocad, Inventor etc) 2 09-03-2005 03:14 PM
