Old 10-03-2008, 09:49 PM
mdierolf is on a distinguished road
How much should 6061 cost?
What is everyone paying for 6061 & mild steel?
The place i've been going to charges $6/lb for 6061 and $1/lb for mild steel.
How does this compare?
Mark
Old 10-03-2008, 10:13 PM
Your $1.00/lb for mild steel seems okay for small quantities.
The $6.00/lb for 6061 seems a bit rich; but I have to admit I have not been keeping really tight tabs on aluminum costs recently.
Old 10-04-2008, 10:47 PM
*Registered User*
fpworks is on a distinguished road
$6/lb for 6061 is insane, generally speaking.
If you're buying extruded (6061-T6511) you should be paying in the neighborhood of $2.30-$2.50 / lb this week depending on the size of the material you're ordering. This is what you usually get from <most> service centers when you order bar stock.
If you're buying cold finished (6061-T651 or 6061-T6) you should be paying $5-6 / lb at the fair market value.
If you're ordering small quantities from one of the online suppliers, you're probably paying for the online convenience and possibly a cut charge.
Old 10-05-2008, 04:19 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
There are a lot of factors, gas prices being one of them. And then you figure that when I buy 3" X 6" extruded bar, I pay $4.50/lb. But if they are out of bar stock and I need it today for instance, I can have it sawed from plate at a cost of $7/lb.
Need A Quote- 6061 just a little complex mc-motorsports Employment Opportunity 6 09-07-2008 02:59 AM
VF2 Ripping Up 6061 Geof Haas Mills 5 02-11-2008 09:25 PM
Using Roughing EM on 6061 mrk CNC Tooling 8 05-31-2007 11:27 AM
End-Mill bit 6061 Ed Williams General Metalwork Discussion 2 05-31-2006 11:18 AM
Parting 6061 ozzie34231 General Metalwork Discussion 9 06-27-2005 12:04 PM
