Old 10-02-2008, 04:18 PM
SQT18MS is on a distinguished road
Drilling 2mm holes through 19mm bolt heads in 316L
In going to drill 2mm holse in bolt heads i various sizes, but the biggest ones are 19mm heads.
The drilling opperation takes place in a pretty stable drilling machine, with max 1000rpm and lowest feed are 0,08mm pr rev. The feed are too high so I have to feed by hand.
Got cooling of corse.
And oh yeah, the material of the bolts are 316L Stailess steel
Anyone have experiense with drilling small holes like these deep in stainless?
Witch drills did you use?
Anyone that can help me with this, I would very much appretiate it.
The job could pay well if I get more holes ot of the drills.
Now I get 2 holes out of every drill and its going SLOW
The drills I tried were the cheapese Prototyp drills, regular HSS with no coating. Got coated Osawa drills coming this weekend, will try those.
Any help here guys????
Old 10-02-2008, 05:14 PM
laka is on a distinguished road
RPM for a drill that size in stainless should be probably around 1900 RPM (at 40 SFM) and the feed probably around 0.001" to 0.002" per revolution. So run at max RPM, and feed by hand at what you think is a decent feed, make sure you get some actual chips and not just dust. Feeding too slow on 316 is not good. Coated drill should help, just make sure they're sharp. and you should be center-drilling first.
Old 10-03-2008, 04:10 AM
davereagan is on a distinguished road
Make sure there is real oil in your coolant, not all synthetic. A split point cobalt drill should hold up well with low cost. Stainless work hardens if you rub on it. Need to drill steadily and keep it cool.
Old 10-03-2008, 12:09 PM
Thanks for the replys.
I am using a quaker coolant, not sure if its syntetic or mineral pr semi.
I get chips when I drill, not dust. The drill is cutting.
And I got 1000rpm max at the spindle, but have to feed by hand.
The drills Im waiting for are tin coated hss drills, I hope that will do the trick.
The first drill I tried were non coated hss drills.
Should have had this job in a machining center, but Im starting my own buisness whit minimal investments.
Any spesific drills in mind anyone?
Old 10-03-2008, 01:12 PM
I just noticed you are in Norway, so any US supplier I could recommend would probably be out of reach. The point you use is important and it needs to be a split point, probably with a 135 degree point. Also, I am pretty sure uncoated cobalt will hold up better than TiN coated HSS. They cost about the same. If you go to www.mcmaster.com and look up these part numbers, you will see what I recommend: 3069A13 $1.48, 28765A12 $1.39 but short length, 29925A912 $2.89 with parabloic flutes I am curious how much you pay for drills over there. Just a friendly offer. If you found these prices attractive, I would be happy to order a bunch of them and then airmail them to you for no added charge at all. You'd probably have them in 6-10 days and total shipping cost would be under US$10.00
Dave
Old 10-03-2008, 02:13 PM
Thanks for the offer davereagan, I would check out youre recomandations ASAP
The first drills I used were about 1$ a piece, and the coated ones I have orderd now are about 1.5$ so they are pretty cheap.
Old 10-11-2008, 02:00 AM
So, now I have some Osawa drills and they last 20 holes (bolts) and I probably drill the hole 4 times faster than with the first ones.
Im very happy about this, cause it`s making me about 150$ in hour in a machine I paied 200$ for
Thanks for all the input guys, have a nice weekend
Old 10-11-2008, 02:02 AM
By the way, the Osawa drills have coated tip and costs about 1,20$
Just orderd up 100 of them, and have 7-800,- bolts in the trunk that need drilling.
Old 10-11-2008, 02:15 AM
Now I'm jealous. Are Osawa drills from Japan?
Old 10-11-2008, 04:42 AM
Im not sure, found an italian page just now.
But would thing theire from japan.
Just google "osawa drills"
I got them from a local dealer.
Will post the spesific drill type, when I get to check it later this weekend.
  #11   Ban this user!
Old 10-11-2008, 12:10 PM
The spesific drill I used are called Osawa Item: 1386STI (I think) and Din: 338
Bolt Heads justCNCit Mechanical Calculations/Engineering Design 4 07-15-2007 09:11 PM
Drilling Stainless 316L Stoneair666 General Metalwork Discussion 28 05-01-2007 07:51 AM
Drilling holes wildcat General Metalwork Discussion 18 01-31-2007 09:38 PM
Drilling a hole in the center of a bolt / newby question stickben Mechanical Calculations/Engineering Design 1 04-30-2006 11:07 AM
Drilling Bolt Hole Patterns TURNER G-Code Programing 17 01-02-2006 06:49 PM
