Hello, I'm wondering what kind of lathe tool bit would generally be used to put an o-ring groove in a flange? In this case the groove would have an ID of about 2.0", OD of 2.250", and the depth would be about 0.075". The flange would be either brass or aluminum. Thank you. |
| just grind your own tool out of a blank, especially if you only need a couple of pieces, unless your good at this kind of work. Otherwise, inserts are available, but I've always ground my own. http://www.sherline.com/grinding.htm http://www.sherline.com/3005pg.htm There are all diffrent size blanks available, just goto your local tool supply, they are common and cheap! |
| How big a square shank tool can you use? First option would be a top notch face groove tool if it fits. You probably can order a solid carbide trepan bar. Or make your own tool with one of those 3/8 or 1/2 inch tools that have a piece of carbide brazed on them if you have a grinder. Having a senior moment, and can't recall their correct name. |
| Thanks to everyone for the replies. I can use up to a 3/8" shank tool. From what I'm seeing, it looks like carbide face-grooving inserts are manufacturer unique, and meant to be used with their specific corresponding holders...all of which I've seen are bigger than 3/8". As far as grinding my own tool bit, well, unfortunately I'm new at this, and, not having any kind of reference material, tutorial, detailed picture, sample to look at, etc., that doesn't seem like the answer at this point. Regards, Nelson |
| Thanks for the link. That's a nice little tutorial on basic tool grinding. I think I'm capable of doing that. Now all I need to know is what a face-grooving cutting tool has to look like...even some kind of rough empirical guidelines. |
| 10* relief, if your good, maybe a 3* rake on the top, 0 is fine though. Pretty straight forward and simple, nothing real critical for an O-ring groove, just make sure you have a nice clean cut on the bottom, that is where the O-ring will seal, the sides will hold it in. Shouldn't be a big deal cutting aluminum, just grind one up and try it, I think you'll be suprised how easy it is, especially after the first tool you grind up. MC |
| face grooving trouble | jheal | EdgeCam | 0 | 06-26-2008 01:50 PM |
| I need help with deep face grooving. | Fred Ashley | General Metalwork Discussion | 7 | 09-13-2007 10:27 AM |
| deep grooving | eject_21 | G-Code Programing | 3 | 06-15-2007 12:59 AM |
| What is the G code for Grooving? Not G75? | cjchands | Mach Software (ArtSoft software) | 7 | 04-22-2007 05:07 PM |
| Ball Nut Mounting Flange Types - Question? | widgitmaster | Linear and Rotary Motion | 7 | 06-14-2006 02:28 PM |
