I am having a problem with milling a slot in thin wall (.014) telescoping brass tubing. There is a .003 difference between the outside diameter of the inner tube and the inside diameter of the outer tube. They telescope perfectly before I cut the slots but stick afterwards. There is no problem with burrs so I can only assume that the tubing is being forced out of round by the milling process. Any thoughts on how to true the tubing afterwards or how to prevent this from happening? |
| A friend of mine made some thin wall parts out of brass. (hobby level, not pro machinist) He placed a wooden dowel rod sized to fit inside the tube first - then machined. It seemed to work well enough for his hobby work. |
Ok, as per previous response, I did try the wooden dowel approach. It didn't work. Maybe because the fit wasn't close enough. Not sure if you are pulling my leg with the ice thing but I will try it for grins and giggles while waiting for clamps and tooling mandrel. Can't imaging someone doing it in production. Anyway, thanks for taking the time to pass on your ideas. |
| Gary |
| What is the best way to cut thin wall brass tubing? | lerman | General Metalwork Discussion | 9 | 03-27-2009 02:58 PM |
| Milling Brass 360, recommendations? | skyline | General Metalwork Discussion | 17 | 06-09-2008 03:58 PM |
| Telescoping leadscrew cover? | phantomcow2 | General Metal Working Machines | 5 | 10-13-2005 11:32 AM |
| More 4th Axis! Milling letters into tubing | corpse | Visual Mill | 4 | 07-28-2005 03:39 PM |
| Milling Brass Question | djacob7 | General Metal Working Machines | 1 | 06-13-2005 04:19 PM |
