Hi, I am still trying to figure out my CNC Lathe. I need a simple way to figure out feed rates for tapping. Specifically, I need to tap using a 5/8x18 tap. I know it's probably very simple, but I am not a machinist, I am simply a "Jill of all trades" trying to learn more. Thank you in advance. Ardis from Eagle View |
| The feed rate (in inches per revolution) is simply 1 divided by the number of threads per inch. A 5/8-18 tap requires a feedrate of 1/18 or .0556 ipr. If you are programming in inches per minute, the feedrate will be the spindle rpm divided by # of threads per inch. For example, at 360 rpm, the feedrate will be 20 ipm (360/18). I assume that your control supports rigid tapping
__________________ Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers Last edited by Eurisko; 09-24-2008 at 03:43 PM. Reason: spelling |
| Need Help!- Feed rate Ovverride also Increases rapid rate. | Korellibopper | Machines running Mach Software | 1 | 01-30-2008 05:37 PM |
| Feed Rate and Spindle Rate for this cut? | DroopyPawn | General Metalwork Discussion | 20 | 11-21-2007 11:12 PM |
| Feed Rate? | bearwen | GRZ Software- MeshCAM | 3 | 04-26-2006 04:52 PM |
| C & Z Feed rate | rfstar | G-Code Programing | 7 | 06-22-2005 12:38 AM |
| How can I up my feed rate ? | ynneb | DIY-CNC Router Table Machines | 7 | 07-12-2004 09:40 PM |
