Old 09-15-2008, 12:04 PM
Router Lady is on a distinguished road
CNC .040 aluminum tricks
Hi Guys I need your help!!
I run a Gerber Sabre 408 CNC router table.
I have routed .040 aluminum in the past and have used a 2 flute upwards spiral bit and run the router at 50 IPM @ 19,000 RPM I need to run the job faster. Any help you could give with this would be great. I also need great edges that will need no filling .
Thanks for you help
Carrie
Old 09-15-2008, 07:39 PM
Matt@RFR is on a distinguished road
Carrie, just switching to a 3 flute endmill will bump your feedrate up to around 85ipm while keeping the same chipload you have now. Who knows, maybe on such thin material a 4 flute (or more?) might not load up. Try it. The worst that should happen is you break the endmill.
Is 19,000rpm your max?
Old 09-16-2008, 10:14 PM
MFassler is on a distinguished road
what size cutter are you using? for those speeds id use as small a cutter as possible so there will be less tool pressure.
Old 09-17-2008, 11:37 AM
My max RPM is 24000
I'm using a 1/4" dia. bit because I also have 1/4" dia holes I have to drill and I don't have a atuomatic tool changer so takes to long to change from a smaller bit to a 1/4" bit.
Thanks for your help if you have any more Ideas let me know but I will try these for now.
Thanks guys
carrie
Old 09-17-2008, 01:22 PM
thescenicroute is on a distinguished road
Do you have a mister on your router? I use water dilluted cutting oil through a mister whenever I cut metal. I can even cut steel with my dinky 5.5 hp routers as long as i have a good chip and I keep the bit and material cool. McMaster Carr sells a great inexpensive option. Part # 10445K34
Smaller cutters are going to take too long and bumping up your rpms is going to get too hot and your going to start to reweld. A bigger bit would got a faster cut time, maybe jump up to 3/8" if your part allows that kind of radius.
I can't stress enough using coolant when cutting metal. Makes all the difference in the world, even on thin sheets.
Tips and Tricks Smitty911 Dolphin CADCAM 9 03-03-2008 11:59 AM
Can a old dog learn new tricks? Doubleddaved Haas Mills 3 02-11-2008 02:35 PM
old dog new tricks lgalla CNCzone Club House 2 08-18-2006 05:58 AM
Tips and Tricks duluthboat Forum Questions or Problems 3 01-30-2004 01:49 PM
Version 19 tip and tricks CNCadmin BobCad-Cam 2 11-26-2003 09:42 AM
