Old 09-15-2008, 01:07 AM
lbrc is on a distinguished road
Looking for the right lathe bit?
Need help finding the correct lathe bit to cut deep into the face of a 2” piece of aluminum round with a post left in the center so I can’t just drill the center and use a boring bar.
Turning the prototype with a straight square end bit was not pretty, there has to be something better, I hope.
Old 09-15-2008, 03:43 AM
M250cnc's Avatar
M250cnc is on a distinguished road
This would be possible with just a boring bar.
I do this stuff a lot.
In the conventional way looking at the end of the bar turning.
Starting close to the boss in the middle while the tool feeds to the left/outside plunge the tool in gradually at a rate that clears the back/clearance of the BB then continue until you come close to larger diameter profile.
Then reverse rotation of the lathe, move the tool into the space you have just turned then feed the tool to rough out the boss.
Just keep repeating this process until you complete the depth.
Then do a finish cut.
This is an ideal CNC job as it would be very repetitive.
HTH
Phil_H
Old 09-15-2008, 05:08 AM
rotonone is on a distinguished road
gday lbrc
the first question i always ask is how many of these items do you intend on producing yourself? if the answer is many then have a look at this range of iscar tooling -
http://www.iscar.com/ProductLines/Pr...LineDetailID/3
these tools are designed to do exactly what you are after however the only problem would be the cost of the tooling which at a guess could be about 200-300$AU, obviously if you are not in AU then the price will be different.
The other option you have if you are not doing too many is to look into the cheaper chinese tooling personally i don't recomened it as the tool holder is not finished as well as it should be i.e there is movment in the pocket, which will result in a poor finish and/or longer machining times.
and finially if your are only doing about 10 of the items i would also suggest fabricating one up in HSS as this is a cheap option. if your are going to go down this route have a look at the website above and copy the tool holder, as best as time will allow, and incorperate the cutting edge into this holder.
i hope this helps
if you have any more questions please don't hesitate to ask
Old 09-15-2008, 05:38 AM
M250cnc's Avatar
Sorry rotonone.
That tool shown in the link would be totally unsuitable to make his part.
My method is achievable and there is no outlay.
Phil_H
Old 09-18-2008, 12:42 PM
mc_n_g is on a distinguished road
Get a form bit ground out of high speed steel and plunge it in with lube. Have a tool and cutter grinder shop to make the form from a clay impression of the inside of the prototype.
Old 09-19-2008, 02:06 AM
oliver9866's Avatar
oliver9866 is an unknown quantity at this point
Smile welcome to try of our cnc routers, share joyments with u
Hi, everyfriend:
glad to offer you our cnc routers here. we professionlly manufacture cnc routers. and if you want DIY cnc routers, we also can offer you spare parts, like spindles, stepper motors, microdivision drivers, controlling card, power supply, linear guideway, dust collector, holddown system. etc. welcome to contact me for your demands. thanks. waiting your reply. welcome.
Email: oliver9866@gmail.com MSN: oliver9866@hotmail.com
Shandong ITOP technology co.,ltd.
Name:	PCB Routers.jpg‎
ID:	66622   Click image for larger version
Name:	cnc routers 6090 3.jpg‎
ID:	66623   Click image for larger version
ID:	66624   Click image for larger version
Name:	wood router 2.jpg‎
We are professional manufacturer of cnc router, cnc wood router, cnc stone router, laser engraving and cutting machine, inkjet printer, textile printer, eco solvent printer, large format printer, color banner printer, and so on.
Sincerely welcome to be our distributor in your marketing.
qingdao mingyang cnc equipment co.,ltd.
Contact: Oliver Zhang
Tel: +86-532-85985933
Fax: +86-532-85981144
Email: oliver@qdmingyang.com
MSN: qdmysk@hotmail.com
Http://www.qdmingyang.com
Old 09-19-2008, 09:43 AM
cad01 is on a distinguished road
Originally Posted by rotonone View Post
gday lbrc
these tools are designed to do exactly what you are after however the only problem would be the cost of the tooling which at a guess could be about 200-300, obviously if you are not in AU then the price will be different.
i hope this helps
In the same line as rotonone, also look into ThinBit face groovers. but as he said, it depends on how many you are running to make it worth it. For the size of the part (it looks fairly small) I would go with a ThinBit. I use them very offten and they hold up very well alot of different materials.
Old 09-19-2008, 11:38 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Do you have a CNC mill or mill and rotary table? If so, rough your pocket on the mill. Finish turn on lathe with a left and a right hand boring bar.
Karl
Old 09-19-2008, 12:08 PM
bborb is on a distinguished road
Look into trepanning tools/tooling.
HTH
Old 09-19-2008, 02:39 PM
oliver9866's Avatar
Smile hello, dear karl, is it these device ?
Karl
hello, dear karl, is it these device ? i offer it by cnc routers and laser machines. hope you can enjoy of them. thanks.
ID:	66639   Click image for larger version
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 03:27 AM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 01:06 AM
How to convert Manual Lathe to CNC Lathe? zaid General Metal Working Machines 4 02-07-2008 12:42 AM
Lathe Comparison - Best small lathe for CNC acondit Mini Lathe 48 03-23-2006 07:10 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 08:36 PM
