Old 09-11-2008, 02:52 PM
Triumph is on a distinguished road
Exclamation Machining Full Hard Stainless
We are trying to machine 304 2B full hard stainless. Are machine is a HAAS VF3. Any suggestions on types of tools and the speeds and feeds we should use? Also, the depth of cut with a .25" tool.
Old 09-11-2008, 07:16 PM
HuFlungDung's Avatar
Moderator
I'm not certain how hard that actually is on the Rockwell scale, probably not very hard. Since the hardness has to be cold worked into the material, it may want to warp all over the place when the stresses are relieved in an uneven manner.
http://www.engineersedge.com/materia...roperties1.htm
Old 09-11-2008, 10:13 PM
MFassler is on a distinguished road
Isnt the 2B rating just a finish type from the manufacture? and not a code for its hardness?
Solidworks, Camworks, Autocad, And Full Cnc Machining Available. Steeda31505 Employment Opportunity 4 12-31-2008 08:54 AM
Hard machining vs. carbon JIMMY Hard and High Speed Machining 11 11-16-2007 07:00 PM
Machining Hard steels at 1400 SFM? Also, plunging question. facegarden General Metalwork Discussion 23 10-17-2007 01:35 PM
on Gildemeister speed 12 -7 hard material machining Ashu Hard and High Speed Machining 0 10-16-2006 07:14 AM
How hard is it to get into CNC Machining small aluminum parts? GreasyMidget General Metalwork Discussion 4 10-12-2006 09:20 PM
