Results 1 to 6 of 6
Thread: 1/16 carbide endmill in 316 Stainless Steel
    Feb 2006
    Atlanta,GA
    I have two slots that I need to cut. First is .118 wide and .039 deep. Second is .068 wide and .068 deep. The endmill is a 3 flute. I have to cut 150 parts with this detail so I need some help with the speeds and feeds. I'm not familiar with such a small endmill. I'm open to any and all suggestions.
    Using a HAAS VF3-SS with Blaser BC-40 NF coolant.
    Apr 2004
    If the endmill is carbide, you'll be restricted by your max RPM. Even at 200 SFPM you're already hitting over 12,000 rpm. And say 0.0002" per tooth per rev you're looking at a feedrate of 7 IPM.
    If you know what brand the endmill is, pretty much all the suppliers will list their recommended speeds/feeds/DOC's.WOC's on their websites/catalogues.
    Oct 2005
    Can you use a slitting saw to make the cut? I think it may be more forgiving.
    Feb 2006
    Atlanta,GA
    I thought about the slitting saw. I may have to go that route if I can't get this to work how I want it to. Thanks for the advice!
    Apr 2006
    CH
    First very important question: Which lubricant do you have ??
    If you have cutting oil (the best for stainless steel)
    Use.Vc = 50m/min , Vf = 180mm/min depth (ap )= 0.5mm
    If you have water soluble oil, reduce the depth... (ap = 0.25maximum)
    Sep 2008
    united kingdom
    HI
    Without more info its hard to say the best way to go about this problem.
    Are you wanting to do both slots with the same tool?? I personally would look at 2 different size tools its an extra expence but worth it for tool life.
    I use alot of endmills and i use sgs (see sgstools.com) not sure what tool your using but sgs are a good endmill
    1. solid carbide endmill sale
      By cnctoybox in forum Product and Manufacturer Announcements
      Last Post: 08-12-2008, 11:30 PM
    2. M2 Steel & an Endmill Question
      By Smrtman5 in forum General Metalwork Discussion
      Last Post: 02-01-2008, 11:56 AM
    3. Machining 304ss with carbide endmill
      By nybuxt in forum General Metalwork Discussion
      Last Post: 12-10-2006, 05:02 PM
    4. .5 Carbide endmill tool life
      By Turn.n.Burn in forum General Metalwork Discussion
      Last Post: 05-29-2006, 11:50 AM
    5. 3/8 Ball Endmill in Tool Steel
      By Freddy in forum Hard and High Speed Machining
      Last Post: 09-08-2003, 04:13 PM
