Old 09-10-2008, 05:31 PM
classictom is on a distinguished road
SFM?
Could someone explain SFM to me? Is it the same as IPM? I am new to milling and would like to start using proper feeds and speed instaed of guessing.
Tom
Old 09-10-2008, 09:52 PM
laka is on a distinguished road
SFM and IPM are different.
SFM (SFPM) is Surface Feet per Minute = Distance in feet the cutting edge (or workpiece on lathe) travels in one minute. Since a tool on a mill is rotating, you have to do some calculations to convert this linear measurement, into circular equivalant.
IPM is calculated from SFM, RPM, and chipload.
RPM = (SFM x 3.82)
Cutter (or workpiece) diameter
IPM = (RPM x Chipload per flute x # of flutes)
ie: 1/2" 3 Flute endmill - 350 SFM - 0.003" chipload per flute
RPM (S) = 2674
IPM (F) = 24.066
If you were to roll the 1/2" diameter tool down a hill at 2674 RPM, in one minute it would have travelled 350 Feet down the hill. Circumference (1.57" x 2674RPM = 4198" = 350 Feet)
When I was first learning, I would grab a Kennametal catalogue and look at all the formulas in the back. I found that it helped me get my head around it. I still use these formulas everyday.
You should never need to guess a SFM, every tool supplier usually will list their recommended SFM's for their products for different materials. You will notice that softer materials will have a higher SFM, and harder materials will have a lower SFM.
hope this helps
Old 09-10-2008, 10:40 PM
Eurisko is on a distinguished road
Well said.
Here's another example:
Let's say you want to drill a .500 inch diameter hole in an aluminum alloy using a high speed steel drill.
According to the reference manuals, a HSS drill should be able to handle 200 SFM in this alloy.
RPM = (SFM x 12) / (pi x drill diameter)
= (200 x 12) / (3.14 x .500)
= 1528
Another reference tells us that the proper feedrate for a .500 diameter drill in this material is .008 inches per revolution (IPR).
Multiplying our RPM (1528) x IPR (.008) gives us a feedrate of 12.2 inches per minute (IPM).
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
