Old 09-10-2008, 10:55 AM
Collin Weisz is on a distinguished road
Question lead machining
Having problems cutting lead-tin alloy with metal cutting circular blades one inch in diameter. Need to cut grooves about .045 in. tried wd-40 didnt help much-metal wants to smear doesnt cut clean tried various speeds the rotating blades work better than a single cutting edge any help?
Old 09-10-2008, 11:41 AM
msomerville is on a distinguished road
I am not familiar with that material but I would use cutting oil for a slitting saw. What do you have your RPMs set at?
Lead Machining Titanium General Material Machining Solutions 0 04-22-2008 02:59 PM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
lead in-lead out on surface toolpath Tugiyana Mastercam 4 05-07-2007 05:16 AM
Machining Lead Alloys Joe_CNC General Metalwork Discussion 0 02-01-2006 11:54 AM
Lead screw machining question CNCadmin General Metalwork Discussion 4 07-12-2004 05:21 PM
