Results 1 to 4 of 4
Thread: Want to do climb milling, how?
    Feb 2007
    Brunei
    Hi all,
    I have CNC X2 mill and most of the times I am doing conventional milling coz that how the machine was set up to do. Looking at the table from the front, when I do a pocket cut, the spindle spins clockwise while the end mill moves in a clockwise direction hence doing the conventional milling method.
    Now I want to try to cut counterclockwise. This will give me the climb milling method. How do I do that? Thanks.
    Alex
    Registered holbieone's Avatar
    Feb 2007
    climb mill vs conventional mill all depends on what side of the tool the stock is on
    look at it like your driving a car ,the car is the tool ,your going forward and if the stock is to your right your climb milling
    if the stock is to your left your conventional milling
    your machine needs to be solid ,no backlash in the axis to climb mill
    climb milling pulls the tool forward so it will cause the backlash to jump around which will result in a poor surface finish and chipped or broken tools
    Apr 2008
    Hi Alex
    don't try and take to big a cut as when you go into the corner of the pocket the cutter will really try to move the machine. Also try to use a cutter that has a radius that is smaller than the smallest radius of the workpiece that you are cutting otherwise the cutter will tend to dwell in the corner. Finally try to ensure that the swarf is removed from around the cutter otherwise it will come back around again as the cutter rotates and this is not good for the cutter or surface finish.
    Oct 2003
    There's an illustration near the bottom of this page.
    http://en.wikipedia.org/wiki/Milling_cutter
    Software For Metalworking
    http://closetolerancesoftware.com
  1. Selecting Climb Or Conventional For 3d
    By moldmker in forum BobCad-Cam
    Last Post: 10-18-2007, 06:21 PM
  2. Maximum Acceptable Backlash and Climb Milling?
    By Oldmanandhistoy in forum General Metalwork Discussion
    Last Post: 10-11-2007, 07:52 PM
  3. Climb or Conventional cutting
    By Glidergider in forum WoodWorking
    Last Post: 09-09-2007, 11:35 AM
  4. climb vs. conventional machining
    By cbass in forum General Metalwork Discussion
    Last Post: 10-23-2006, 01:34 PM
  5. Is the Syil / Sieg X3 suitable for climb milling?
    By Ed from NY in forum Syil Products
    Last Post: 08-30-2006, 11:10 AM
