Old 09-01-2008, 05:02 PM
mlanders is on a distinguished road
face grooving 304L for 32 finish
Hello,
I'm having trouble getting the required 32 finish on the inside corners of a
1.365-1.685 face groove with a depth of Z-.104.
The material is 304L stainless.
Using a .118 wide Iscar face groover (.010 radius corners).to rough and a . 079 face groover (.005 radius corners)
(these are my only choices).
The finisher is doing great on the sides and floor of groove but I'm getting a
slight chatter on inside corners.
Working with .0005 to .001 ipr feed.
300-350 sfm. I tried up to 400 sfm but the problem worsened.
I've used several tool paths but still have'nt found the right combo.
Any suggestions are much appreciated.
By the way - I am glad I found this site, it looks great.
Thanks again!
Old 09-01-2008, 06:20 PM
cam1 is on a distinguished road
Hi: In general when chatter ocurrs, you have 3 choices:
1. Up the feedrate
2. Drop the speed
3. Do both
How much material are you leaving to finish?
What kind of a toolpath: Plung rough and finish with a single sweep (feed tool into Z on ID wall, face outwards and retract on Z at OD wall?)
regards
Can't Fix Stupid
Old 09-03-2008, 12:54 PM
Thanks for the advice.
When I had the most luck I was leaving .005 on each surface.
The toolpath was :1)radius corner and plunge at ID 2)radius corner and plunge at OD then feed in X down to ID and feed out to Z.015
That seemed to work best-
Thanks again-
ML
face grooving trouble jheal EdgeCam 0 06-26-2008 01:50 PM
I need help with deep face grooving. Fred Ashley General Metalwork Discussion 7 09-13-2007 10:27 AM
Tools for threading and face-grooving 6061-Al on lathe SRT Mike General Metal Working Machines 5 08-15-2007 12:59 PM
Face Mills? Which one to choose for a good finish on aluminum? peter.blais General Metal Working Machines 20 08-25-2006 10:41 AM
angular contact bearings face to face?? powerfade DIY-CNC Router Table Machines 2 06-18-2005 11:01 PM
