Old 08-29-2008, 12:33 AM
Camorenob is on a distinguished road
Problems with manufacturing nitrnics 50
good evening all community I have problems with manufacturings of speller ring of nitronics 50, this part have out diameter of 11.974" and in diameter of 11.250" and width of 1.250", the part when I finish of manufacturig in CNC lathe mazak have oval both diameters by .007" plus and minus and I unkwon how control this problems somebody can help me, or say me what is the method more correct for resolve this problems, I hope that some member can help me, thanks.
Old 08-29-2008, 06:28 PM
MFassler is on a distinguished road
Well I'll bite,First off what type of tools are you using? You need too use something with a tough grade for this type of stainless. Read this webpage for some more info.
http://www.hpalloy.com/alloys/descri...ITRONIC50.html
use slower SFM and heavier feed rate possibly use a second tool for cleaning up both the id and od after roughing. Make sure your insert edge isnt breaking down too quickly,if it is slow your speeds down and use a larger radius insert.
What type of jaws are you using and how much chuck pressure?
What speeds are you currently using?
Old 08-29-2008, 10:46 PM
respond about of condition jaws and pressure
Before that all thank you for answering, my name is Ing. Carlos Alberto Moreno barbosa I am from Mexico, the conditions of hold is 100 PSI with 0.500" inches and my jaws is soft, I hope this data will be important for you.
Need Help!- Nobody seems interested in manufacturing... MajHarryMorant Want To Buy...Need help! 1 02-06-2008 01:33 PM
Manufacturing upswing or down? thetrillionaire CNCzone Club House 3 12-30-2007 04:51 PM
Drill Bit Manufacturing kenbarra Mechanical Calculations/Engineering Design 12 07-30-2007 11:35 PM
manufacturing and the USA MBG CNCzone Club House 90 10-16-2005 03:48 PM
Where is Pro Manufacturing? utengineer04 PTC Pro/Manufacture 3 08-30-2005 10:11 AM
