Old 08-19-2008, 02:17 PM
Gene-Yo is on a distinguished road
MaxNc 10 Basic Questions
I recently acquired a MaxNc 10 and need a little help from someone that knows this instrument and hopefully has the instruction manual.
1. What is the collet sizes used? This one only came with the 1/8" collet and need to order a 3/8" and 1/4" collet or perhaps a collet set. Any chance they're the same as Sherline or Taig? I have the same question on how to add a drill chuck as it appears you can order this direct from Maxnc but curious if it's the same as Sherline or Taig?
2. It has 3 small Nema 23 steppers (4 wire) and the control box but no software. Will Artsoft Mach3 work with this control box which if factory installed and attached to the back of the mill column. It has a standard 24 pin parallel cable input. Or is there special software required for this setup?
3. I've read that some of these Maxnc stepper drivers are problematic. I have a spare Xylotex board however would like to try the original to find out if it works o.k. before spending hours of work on this switch out. Any suggestions or should I just assume the worst and start the modification perhaps even putting on new stepper motors and upgraded shaft couplers to boot.
Old 08-29-2008, 10:36 AM
rdstillw is on a distinguished road
Control Software
Try using TurboCNC its free and works great.
Need Help!- basic questions about CAD and CAM... max90272 General CAM Discussion 9 06-28-2008 02:15 AM
Very Basic CAM Questions kochevnik General CNC (Mill and Lathe) Control Software (NC) 4 06-26-2008 07:59 AM
Some really basic Questions Chris64 Mach Software (ArtSoft software) 7 01-30-2008 12:39 PM
Some basic questions about (DIY) cnc mihaelbele DIY-CNC Router Table Machines 1 09-07-2007 03:07 PM
Basic Questions NinerSevenTango FeatureCAM CAD/CAM 6 01-05-2007 09:53 PM
