Old 08-14-2008, 09:08 PM
tibbsmn is on a distinguished road
Machining Nitronic 50
I am trying to turn a part that is nitronic 50, turning it is no problem but drilling it is another story. Does anyone have any experience with this stuff. I tried 60 sfm f.008 got 2 inches deep and burned up the drill. Any help would be appreciated.
Tibbsmn
Old 08-17-2008, 08:06 PM
MFassler is on a distinguished road
what type of drill are you using? most likely you will need a tool with coolant through too help prevent work hardening and have a peck in there somewhere to help flush chips out. heres some info I found on it.
MACHINING DATA
Carbide tools are suggested
for rates better than 50% of Type 304.
Machining Type Suggested starting rates are:
Single Point turning : Roughing - 0.15" depth, 0.015"/rev feed -175 SFM
Finishing - 0.025" depth, 0.007"/rev feed - 200 SFM
Drilling : 1/4" Dia hole - 0.004"/rev feed - 60 SFM
1/2" Dia hole - 0.007"/rev feed - 60 SFM
3/4" Dia hole - 0.010"/rev feed - 60 SFM
Reaming : Feed - same as drilling - 100 SFM
Side and Slot Milling : Roughing - 0.25" depth - 0.007"/tooth feed - 125SFM
Finishing - 0.050" depth - 0.009"/tooth feed - 140SFM
These rates are for carbide tools,
Type C-2 for roughing, drilling and reaming.
Type C-3 for finishing.
Old 08-17-2008, 09:29 PM
rajanvadakkepat is on a distinguished road
use HSS/bronze drills (dormer drill) PFX group.
use peck.
use coolant
RPM set as 150~200.
good luck.
Old 08-19-2008, 10:26 AM
Figured this one out
Here is what I ended up doing and it worked beautiful.
I was drilling 1.5" hole 4" deep used 25sfm and f.008 worked great.
Thanks for all the input.
Old 08-20-2008, 11:17 AM
vigilante212 is on a distinguished road
Yea Nitronic 50 is really a pain to machine. Slow RPM high chip load. If you have to pilot drill use as small a drill as you can.
Old 09-09-2010, 09:31 PM
PaulRBK is on a distinguished road
Old 09-12-2010, 07:31 PM
MikeZee is on a distinguished road
I used to machine Nitronic 40 all the time, space shuttle main engine parts. Not really too bad, heavy feed, tons of coolant and a little bit of know how.
CNC Machining (Who's been in it?) omy005 Haas Mills 6 06-08-2008 03:24 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Nitronic 50 Chuck Reamer Composites, Exotic Metals etc 3 02-28-2007 09:23 PM
Nitronic 60 replacements? GMTool Composites, Exotic Metals etc 0 05-15-2006 03:06 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
