Old 08-14-2008, 08:54 AM
srmaietta is on a distinguished road
tapping oils..
Hey there.. In the flammable stuff cabinet in my shop I found a few gallons each of "Dark cutting oil" and "light cutting oil". Whats the difference? I've been using the dark as a general purpose cutting/tapping lube but of course Id like to know the diff between the two.
anyone?
thanks
~Steve
Old 08-14-2008, 08:59 AM
HuFlungDung's Avatar
Moderator
One of them is for 'lights out machining', while the other can be safely used in the daylight
Seriously, I think it has to do with the amount of the sulfer compound additive. The dark stuff is what I've always used when tapping steels of any type. Seems to promote tap life somehow, I guess it prevents that 'chip welding' phenomena that wants to break off the sharp tips of the tap teeth. This effect then produces cleaner looking threads. I think the guys who run pipe threaders all use the dark stuff, too.
Old 08-17-2008, 11:37 AM
Thanks, HuFlung..
we threw out a ton of the stuff but I kept a gallon of each for general use.. It should last me a while and then I can get something more specific if I need.
Makes sense about the pipe threading guys using the dark stuff because alot of the jugs of the dark were Ridgid branded.
~Steve
Suggestion for swiss cutting oils EvansMachine CNC Swiss Screw Machines 18 03-11-2011 07:34 PM
Need info on Cutting oils widgitmaster General Metal Working Machines 16 04-03-2007 02:14 PM
oils for Cincom F12 emilm General Metal Working Machines 1 09-27-2005 05:40 PM
