| I was offered one of these: http://www.makita.com/menu.php?pg=pr...det&tag=LS1040 at less than half local market price, what do you guys think about cutting solid aluminium bars with a 100 teeth blade? The blade is also Makita, marketed as an aluminium blade, the bars I want to cut are most of the time under one inch diameter. I know it can cut extrusions like a charm, my doubt is solid bars. Thanks! Pablo |
| Sure. Use a triple chip carbide blade. I have used a Makita sliding compound saw to hack my way through 1.75" plate, 12" long. Its a bit of work, but it will do it. A bit of lube is required to prevent chip jamming the tooth gullets. Of course, hot lube is stinky smoky, so you might like adequate ventilation in the area.
| Ditto. Figure out a good way to clamp the material down and you can get very accurate very quick cuts. I have used a 12" Dewalt to go through 2" by 4" aluminum bar in a few seconds using the triple chip blade.
| I have a 12" Dewalt and I use a stick lubricant when cutting Alum, cuts like butter. I have seen small misters used but I find them to messy. I agree with Geof you need to clamp you material, there is no way you can hold it by hand. Either way its a great thing to have in the shop and at that price jump on it.
__________________ I'm not lazy..., I'm efficient! HAAS GR-408 |
| Dear peu, Mine is a Dewalt. My advice is to put a pair of tights/stockings/pantyhose over the motor ventilation slots. It stops the Al. swarf from getting into the motor and wrecking it. Best wishes, Martin |
| Sheet Metal Miter Not Good Need Help... | RMS | Solidworks | 5 | 08-27-2007 07:21 AM |
| brass miter gear supplier | ikkedus | Hobby Discussion | 5 | 04-28-2007 03:41 AM |
| Small Threading Bars | Bridged | Metal Working Tooling | 3 | 12-10-2006 12:50 AM |
| Custome Tool Bars | JOE65 | Autodesk Software (Autocad, Inventor etc) | 1 | 02-12-2004 10:11 AM |
| Tool bars | MPE racing | General CAM Discussion | 6 | 06-24-2003 06:20 PM |
