Hi everyone, I needed some guidance with trying something I haven't done before. I have been asked to help make some punching dies for PCBs. Most punches will be 0.8mm-1.6mm in dia. These will be coming from http://industrialpunches.com/products/ip1.html Now the thing is that I have never drilled die steel and maybe some one could help with what feed, rpm and peck settings should I be trying to drill 1mm holes in say 8mm thick die steel plates. I will be using 1mm standard carbide PCB drills. Thanks for your help. Dev |
| Mmhhh it's not good idea to use PCB drill. The carbide of PCB drill is designed for abrasive plastics and not for steel. It's too brittle for steel. Your die, is it already hardened or annhealed ??. If it's hardened, good luck !!! If it's anhealed, it's better. For die steel, use common drill on cemented carbide. You can use the following cutting parameters: Vc = 50m/min ( S = 20'000 for diam 0.8, S = 10'000 for diam 1.6mm) f = 0.001xD pecking cycle = 0.4xD Use cutting oil or air blow |
| Drilling very small holes | William Demuth | CNCzone Club House | 7 | 12-21-2008 03:56 PM |
| deep drilling small holes in aluminum | Fremont Dave | General Metalwork Discussion | 13 | 11-25-2007 01:03 AM |
| Drilling holes? | Cartierusm | DIY-CNC Router Table Machines | 12 | 10-26-2007 04:16 PM |
| Drilling holes | wildcat | General Metalwork Discussion | 18 | 01-31-2007 09:38 PM |
| drilling holes | WOODKNACK | SheetCam | 1 | 11-30-2006 08:10 PM |
