I'm trying to install bushings into the aluminum table on my Haas gantry router to use for part alignment and fixture location the bushings are supposed to be press fit into the table and slip fit a 1/2" dowel pin the OD is .7518 the ID is .5005 now Im milling holes in the table for these bushings to a diameter of .7518 and pounding them in by hand with a hammer and soft block of aluminum the problem is, the 1/2" dowels will only slip into 1 out of 10 when Im done, the rest are too tight all these bushing slip over the pin fine prior to installation the pins measure .500 what am I doing wrong? what would you guys recomend for the ones too tight? pull them out? open them up somehow? is the .5005 ID bushing too tight? should I find something .501? I tried a reamer unsuccessfully, and we don't have a tool to extract the bushings (yet) thanks in advance, Kenny |
| You say the bushings are 0.7518 and your hole is 0.7518 so they should still have the .5005 ID after inserting them in the table. Are you using something like Never Seize on the bushings and the hole in the table? Many times when pushing steel into aluminum it will gall up and this squeezes the bushings undersize. Bashing them in is maybe not the best practise; it is very easy to get the bushing going in at a slight angle which increases the chance of galling. I suggest tapping the bottom of the holes 1/2-NF then screw in a stud and use this to pull the bushings in with a washer and nut. This holds the bushing in alignment better and pulls it in evenly. Are these bushings hardened? You will never ream or bore them to size if they are, and you are going to have a bit of fun getting them out. To get them out if they are hard you can try "hydraulic extraction"; provided you have not bored all the way through the table. Make a collar piece that is maybe 3" diameter, about 3/4" thick with a hole the same size as the bushing ID. Make a drift that is a slip fit in the bushing and collar piece with a larger head; the length of the slip fit size should be the length of the bushing plus the collar thickness, the head can be about 1" long. You fill the bushing almost to the top with grease. Put the drift through the collar and down into the top of the grease filled bushing. Give the head of the drift a mighty blow with a good big hammer. If everything goes correctly the hydraulic pressure created by the hammer blow on the drift forces the bushing up; you may need to refill it with grease for a second or third shot. The collar is to hold the drift true and it also protects the table and prevent a squirt of grease coming out the side of the pin and maybe hitting you in the eye.
| yes, the bushings are hard but what about maybe using a grinding compound and "drill" them with one of the 1/2" hardened dowels? wishful thinking? I like your idea of pulling the bushing in with a stud, nut and washer, wish I'd have done that first and I tried a less involved version of the hydraulic trick, but couldn't give it a very mighty blow without going the extra mile like you describe. the extractor tool I found is a couple hundred $$ so I'll be making a guide collar to try first if it comes to it |
![]() If you want to try lapping them with grinding paste do not use the hardened dowels use a piece of brass. Machine the brass a few thou oversize for a length of about .2" then relieve it to a bit less than 1/2" for a total length that is longer than the bushing; then split the end crossways. The split allows the brass 'hone' to spring into the hole and the relief means it will not bellmouth the hole. Being brass it is softer so the grinding paste embeds and grinds the bushing.
| HUGE thanks Geof! thats some ingenious stuff there! I wish I worked around people like you, I'm 2 years into machining, self-taught, and I'm the answer guy at my shop Nobody here could help me on this thanks again, Kenny |
| Drop the bushings into the freezer for a bit (or into a container of dry ice), it will make assembly much easier,in fact the bushings will probably drop right in. regards
__________________ ---------------- Can't Fix Stupid |
| This procedure is used to shrink valve seats into aluminum cylinder heads.
| Heat the hole if possible and shrink the bushing. I'm 100% against hammers for precision fitting. And use a heat gun, not a torch (and yea, it might take a while). Good luck |
Heating the hole may be a bit tricky, he is dealing with a 4' by 8' piece of 1" 6061. Yea it may take a while.
#10
| And I belive they were 30mm OD with .010mm interference. |
#11
| In a situation like that, I would probably make the holes what I call a "push fit", which means you wouldn't have to press them, or shrink fit them, but it would require effort to fit them, and put some permatex or loctite cylindrical locker on them. Good stuff! Trust me! You just can't get it hot, which shouldn't be a problem. |
#12
| Just for fun I looked up the thermal expansion of aluminum; 24 x 10^-6/degree C. Eight feet is about 100 inches and taking the table up to 140 C is a change of 120 degres C; it will expand almost 0.3". Freezing the bushings is more practical.
| Bob CAD woes | Mr. LocoMartin | BobCad-Cam | 23 | 01-25-2008 02:18 PM |
| Mach2 woes, again | Rustybolt | Mach Mill | 7 | 06-16-2007 09:27 AM |
| NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? | dsmdude | Bending, Forging,Extrusion... | 6 | 04-13-2007 04:01 PM |
| Spindle woes | inertialabs | Bridgeport and Hardinge Mills | 20 | 02-09-2007 06:43 PM |
| THK HSR35 woes | Corvus corax | Linear and Rotary Motion | 5 | 11-07-2005 08:14 PM |
