Old 08-07-2008, 04:56 PM
laka is on a distinguished road
Broaching screwdriver slots on lathe
Has anyone ever seen a tool that can broach a slot on the face of a piece for a flathead screwdriver?
We need to make a bunch of brass shear-pins with a slot on the face, I was thinking of using something like a hacksaw blade in the turret and moving the X axis across the face of the part with the spindle locked. Then just part them off.
Old 08-07-2008, 05:10 PM
Originally Posted by laka View Post
.....We need to make a bunch of brass shear-pins with a slot on the face, I was thinking of using something like a hacksaw blade in the turret and moving the X axis across the face of the part with the spindle locked. Then just part them off.
Don't use a hacksaw blade, just use a single point tool and take several cuts each a few thou deep. You should be able to do it at a very fast feed rate, maybe even a rapid, because your feed rate in this instance is actually your cutting speed.
Old 08-07-2008, 07:15 PM
Crap.. I just checked and our lathe doesn't have a spindle lock, only spindle positioning. Do you think doing multiple passes would work still, or would she move around?
Old 08-07-2008, 07:44 PM
Cross fingers and try; spindle orientation (positioning) can hold the position quite good provided not much turning force is exerted. If your cutter is exactly on center iot should not have much tendency to turn the spindle.
Old 08-07-2008, 08:06 PM
cam1 is on a distinguished road
Hi:
If the tool is dead nuts on center there will be no force to cause rotation. (in theory)
regards
Can't Fix Stupid
Old 08-15-2008, 02:53 PM
AR1911 is on a distinguished road
If you have a backgear, leave the bullgear engage (pin in the side of the gear) while the backgear is engaged. It will be locked solid.
Don't forget to undo it before you hit the power switch
Rotary Broaching rhino General Metalwork Discussion 10 09-16-2011 01:15 PM
Broaching on CNC Mill? tkoden General Metal Working Machines 14 09-16-2011 01:08 PM
Which press for broaching? Arnaudb General Metalwork Discussion 3 03-29-2008 08:19 PM
Keyway broaching on Lathe (need Y axis?) pmurdock General Metalwork Discussion 3 12-29-2007 09:20 AM
Broaching advice Al_The_Man General Metalwork Discussion 9 12-19-2006 05:03 AM
