So here is another one to add to my newbie questions. When you guys buy parallels, vee blocks, 123 blocks, how do you keep them from rusting? Bought some stuff a few weeks ago and noticed today already rusting. Wd40 got most of it off, so decided to spray everything really good and let it sit for a while. So wondering if there is something standard you guys do when get new stuff, or to keep them rust free as you own them. Thanks. |
| I find the more you use them the less they rust. If they sit still, they are gonna rust! What is it "A rolling stone Gathers no Moss"????
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
| Have a 1/8 set of parallels and really only have been using 3 of the sizes so far. It's those 3 that are rusting, from the oils and sweat on my hands. I use them a lot. It's funny because it's all my brown & sharpe stuff that's rusting. My spi stuff is fine. I have also seen various parallels that were beat to hell, but no rust. Hopefully the wd40 will help and will try wiping them down better after I use them. But if anyone has any tips, would be appreciated. |
| Good A/C and check your coolant with a refractometer to make sure you are at the right levels and last I use gun spray and dont touch what you are not about to use the oil on your fingers is one of the most leading causes to these problems. |
| No offense guys buy it's not the oil in your hands it's the sweat that you may not perceive as being there that is saline, and is speeding up the oxidation. Some peoples sweat is more acidic than others. Oil is a better rust preventative. Definately check your coolant concentrations. For parallels I don't bother spending the $$$$ on a fancy set. Just get some from shars. I've got 2 sets and have no rust issues with them.
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Check out this tip from Frank Ford (the man's a genius). "Killing rust while it sleeps". http://www.frets.com/FRETSPages/Mach...stremoval.html With credit to FF.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| Forget about WD 40. It's a penetrating oil, and doesn't work well at all at preventing rust, as it evaporates. I started using a product called Krown KL73 4 yrs. ago. It is a vegetable oil based rust inhibitor that does not evaporate or gel over time. I have my shop in a garage where steel rusts in front of your eyes, and since I strated to use this product not a single tool has a spot of rust. I spray down my machines and collets afterwards to prevent rust on the tables and ways. No more rust problems. http://www.krownindustrial.com/produ...p?product=kl73 regards
__________________ ---------------- Can't Fix Stupid |
#10
| Here is what I do in Maine, where the summers are very humid. I mix up a 50/50 mixture of my watersoluble machining oil with water and shake the you know what out of it. I then spray it on my machine tables, vises, v blocks, parallels etc. The water portion of it evaporates and leaves a nice coating of mineral oil behind. Never any rust. And yes WD40 stinks for rust prevention. Hope this helps. |
#12
| Thanks. Ended up getting something from a gun shop in the area called breakfree clp. Brought home my parallells, vee blocks, and 123 blocks. Been soaking them all weekend in this stuff. This shop has no ac. Hot and humid chicago summer. Would be better off leaving them outside laying in the grass I think. Plastic case, then inside a metal toolbox. Whatever gets left on them has no way out. Will just clean them better and hopefully this stuff helps. |
| Reconditioning and rust | ozzie34231 | General Metalwork Discussion | 6 | 12-11-2007 02:18 PM |
| RUST and the other evils | automizer | Haas Mills | 22 | 10-12-2007 12:52 AM |
| New SX3 (green with a little rust red) | Yojinbo | Benchtop Machines | 3 | 09-13-2007 11:10 AM |
| Rust and tram | Vern Smith | Haas Mills | 5 | 06-26-2007 06:22 PM |
| rust prevention | coolman | General Metalwork Discussion | 2 | 01-22-2005 11:32 PM |
