I have a bridgeport series II with a heidenhain tnc 151 control. Turning down .750 outside diameter to a .375 outside diameter .750 depth in 11L17 steel this is leaded free machining steel Right now I'm using a .625 diameter four flute cobalt endmill running the helical passes around the diameter .0625 wide and .050 depth per rev 900 rpm 10 ipm with flood coolant them I come in .002 circle path around the diameter for cleanup bottom and side. This makes a beautiful part only problem it only makes about 15 before I start seeing a big taper about .010 changing the endmill straightens it out what can I do to prolong the tooling besides buying a lathe |
| I think you are maybe running a bit fast and the cut is too small. On something like that using that cutter I would probably run 500 to 600 rpm and make a first pass down taking off nearly the full amount at the same 0.05 depth but maybe half the feed. Then bump the speed for a final clean up pass. But my preffered cutter would be 1/2 coated carbide running at 2000 rpm, a much faster feed of course, and I would do the clean up with a second cutter. When my first cutter started going I would move the second one up to first and put a new cutter as second.
I think you might get much more deflection especially as you get close to size, and horrendous chatter.
| As long as the endmill is center cutting, then It can be used for Helical milling. Maybe if you had a small corner rad on the tool, the tips would last longer, but that's about it. I really like using the Garr VRX mills for that sort of thing!!!!
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
| Please help, which Lathe+Mill should I buy | luismat | General Metal Working Machines | 3 | 05-25-2007 01:07 PM |
| Mill and lathe | drafting101 | Solidworks | 4 | 05-16-2007 08:06 AM |
| Fanuc 6mb do I need a BTR?? Also it wont helical mill ? | mt92 | Fanuc | 3 | 10-18-2006 10:25 PM |
| Fagor 8055 Mill Sample Code and Helical Interpolation | sailcam | G-Code Programing | 3 | 10-12-2006 06:37 AM |
| G2/g3 Helical In Yz(g19) | leggetmachine | G-Code Programing | 4 | 03-22-2006 10:48 PM |
