I have seen these carbide tipped lathe tools and wondering what they are for. If you look at it from the top it's a perfect rectangle. No cutting angles, no radius on the tip, no rake. There is a little bit of relief though. I'm sure you guys will laugh at me, but thought it was some type of blank so took it over to the pedastel grinder and tried to put some cutting angles on it. Didn't make much progress. They seem pretty strong. So I guess I have 2 questions. Can you grind carbide tipped lathe tools? Never really worked with these much, and ones I have used were already a good shaped tool. And the tool I explained, the rectangle shaped tool, what is it for? Thanks |
| Yeppers, its most likely a blank ! I worked in a large shop where we often used them to make special tools for purpose. They are grindable but not with the common soft stone. it is best to EDM to form. Altho they have been used in very large manual lathe apps for roughing, the changeable insert has reduced their use.
__________________ Don IH v-3 early model owner |
| If you Googled 'brazed carbide lathe tools' you might find some information, or Google KBC Tools or Thomas Skinner & Son
| tool adaptor for solid carbide drills | dhiruj | General Metalwork Discussion | 0 | 03-19-2007 03:52 PM |
| .5 Carbide endmill tool life | Turn.n.Burn | General Metalwork Discussion | 6 | 05-29-2006 11:50 AM |
| carbide parting tool for mini lathe? | Runner4404spd | Mini Lathe | 2 | 03-04-2006 04:58 PM |
| Carbide tool life? | ozzie34231 | General Metalwork Discussion | 11 | 11-01-2005 08:33 AM |
| Poor Carbide Tool Life | CoolHand | Hard and High Speed Machining | 16 | 09-12-2003 06:55 PM |
