Old 07-26-2008, 12:53 PM
zhagoox is on a distinguished road
Drill Chuck + End Mills
Hello. I've built a milling machine recently. It has a hollow spindle for a drawbar and a morse #2 taper. I do have a collet set, but it's a hassle to keep changing the collets, not to mention that the gripping force is on the low side and the small diameters some times just slip.
I was wondering: if I can get an integral shank (no jacobs taper) drill chuck with a threaded back for a drawbar, do you think I can use it to hold end mills? This is a small 1/2 HP machine and I'm not attempting huge cuts with it. I just want to have the convenience of an adjustable holding system...
P. S. Don't try milling on the drill press. I think I've ****ed up the bearings.
Old 07-26-2008, 02:15 PM
Mike Horne is on a distinguished road
Nope, endmills in drill chucks are mostly a no-no Wrong tool for the wrong job. There is simply not enough holding power.
Morse taper #2 weldon style holders are availabe on the cheap from several places.
If you don't have variable speed, I'd get cutters with flute and diameter combinations that match your available speeds for the material you want to cut and stick with that.
Otherwise, you'll likely have some problems with cutter life like I did
Mike
Old 07-26-2008, 02:26 PM
Of course it is a No, No to some people, but on a 1/2hp machine a good drill chuck has ample holding power. If it is an integral shank chuck and it is held in the morse taper with a draw bar then it will work fine. I have even held milling cutters, and taps, in a good quality integral shank chuck on a CNC mill. It is necessary to be gentle with feeds but that is all.
Old 07-26-2008, 02:53 PM
So that's where I went wrong I left off the draw bar... so the shank kept dropping out of the machine. With predictably bad results. Ah, the joys of learning.
Thanks Geof!
Mike
Old 07-26-2008, 03:58 PM
cam1 is on a distinguished road
Too much stickout from the spindle nose when you mount an endmill in the drill chuck.I'd recommend to stick with collets for milling.Just because it fits, doesn't mean it's made for the process.......
cheers
Can't Fix Stupid
Old 07-26-2008, 05:25 PM
*Registered*
Mike Stevenson is on a distinguished road
Do not use a Drill Chuck for holding end mills for any reason. Chucks are designed to grip drills and push them straight down only. They are not intended for the lateral forces of horizontal milling. It can ruin the chuck and jam the clamping mechinism. It's also dangerous because the cutter can come loose and fly out of the chuck. Please work safe when using machine tools.
Old 07-27-2008, 09:55 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Only time to use an endmill in a drill chuck is if you are going to drill with it, and it can still work poorly even for that.
A drawbar is crucial for an MT taper that is used for milling.
www.integratedmechanical.ca
Old 07-28-2008, 10:44 PM
So there is no way to have a single tool holder that works for many diameters?
Old 07-28-2008, 11:12 PM
*Registered*
Unfortunately no. You have two choices only:
1. Hard holders that only hold one size.
2. Collets held in a collet chuck.
End mills must be held rigidly. And believe me tool changes are the least of your worries.
Old 07-29-2008, 05:10 PM
sergizmo is on a distinguished road
You can get HSS 3/8" shank end mills in a variety of sizes. From 1/8" up to 3/8".
  #11   Ban this user!
Old 08-20-2008, 01:15 PM
vigilante212 is on a distinguished road
Something like this should work well even though it says its for woodworking.
http://www.woodcraft.com/family.aspx...fcode=05INFROO
  #12   Ban this user!
Old 08-20-2008, 01:24 PM
NEATman is on a distinguished road
Here are #2 Morse taper end mill holers with a draw bar thread:
http://littlemachineshop.com/product...1978&category=
NEATman
Using collet instead of drill chuck? for drilling steel Rich05 General Metalwork Discussion 7 07-13-2008 11:53 PM
remove drill chuck jwallace Benchtop Machines 8 02-23-2008 02:06 PM
Porter Cable Drill Chuck Mod.. Any ideas? Gene-Yo DIY-CNC Router Table Machines 9 11-13-2006 01:14 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 02:20 AM
Drill chuck on my router? Should I? borrisl DIY-CNC Router Table Machines 9 01-29-2006 03:03 PM
