Results 1 to 8 of 8
Thread: Material for prototyping
    Sep 2004
    We have a small shop with a few cnc lathes + cnc mills.
    We are in the process of learing the cnc mill as it was recently purchased. I am relatively new to machining.
    While learning we use scrap metal we find around in the shop. Our regular jobs are with aluminum and steel.
    I was wondering what would be the ideal material to be used while learning the machine ?
    Ultimately, I was thinking of some sort of clay which could be shaped and hardened into the stock size we are working on. This would prevent us from ordering stock everytime we want to test and learn on a new part. This would probably be cheaper as well.
    Is something like this available ? What would you recommend we do ? Any suggestions ?
    Again, I am new to this so I apologize if this question is not realistic.
    Thanks,
    Fred
    Dec 2003
    Is'nt there some kind of machining wax that the jewellery industry uses for molds etc?
    Al
    Gold Member
    Apr 2003
    Ohio, USA
    You can use particle board, cut's really nice, there is a commercial machining type but I would guess reasonably expensive just for learning, you can glue up pieces if you need greater thickness.
    Ken
    Registered NeoMoses's Avatar
    Apr 2003
    Prolly' in the Shop :)
    Wax is one of the most common prototyping/learning materials. It's about the same price as aluminum, but it's re-usable if you recover it. Also, tool wear is pretty much nonexistant.
    Also good for prototyping is foam, such as HDU. Wood sometimes works as well, but all 'prototyping materials' will give you one problem. They don't demonstrate the real chip loads and how it affects cutting in the real material. This will show up as chatter, premature tool failure, broken tools, and poor surface finish when you switch to the real materials.
    Once you're fairly comfortable with machining, aluminum is a good medium to prototype in for the above reason.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Quote Originally Posted by Pharkas
    Blue styro from the home building supply stores - cuts fast and smooth - but makes a heck of a mess - don't suck it in yer lungs either, but cheap and available. Glue it up with white glue I suppose - resins, acetone, etc will eat it.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Aug 2003
    az
    I went to the craft store with my wife and bought some of that grey foam that they set flowers in. It's pretty firm, and has a small grain. You need to use a shop vac with it but it's really cheap, and cuts well. That machinable wax I have seen in the Travers catalog is big bucks. Might as well use aluminum.
    I can't see anyone recovering wax chips, melting them down and reforming them. Sounds like a PITA.
    Mar 2004
    Sweden
    For learning and testing?
    Use wood.
    --Sven
    Registered cybertek's Avatar
    May 2003
    USA Texas
    why dont you make a furnace that you can recast the scrap aluminum into
    stock, for prototyping only
    1. Radius material setup
      By MikeA in forum Mastercam
      Last Post: 04-25-2005, 10:46 AM
    2. Help with warping material
      By snaggletto in forum General Metalwork Discussion
      Last Post: 04-08-2005, 11:22 PM
    3. Drilling a perpendicular hole in drill rod material
      By ngr1 in forum General Metalwork Discussion
      Last Post: 12-04-2004, 10:16 AM
    4. how to mill 7075 T6 sheet material
      By gcamlibel in forum General Metal Working Machines
      Last Post: 09-08-2004, 02:06 PM
    5. Material removel
      By mace in forum PTC Pro/Manufacture
      Last Post: 09-10-2003, 04:31 PM
