Old 07-21-2008, 02:09 AM
djnbig's Avatar
Machining Monster
djnbig is on a distinguished road
What sort of machine would manufactures be using?
I'm wondering what types of machines/setups manufactures would be using to make the small aluminum parts such as the ones used for R/C cars. As you see in the link below, the part is very small yet quite detailed/complex. They would also be making ten's of thousands of these parts, just curious what they would be using to make all these small parts.
http://www.integy.com/cgi-bin/webc.c...=4762&p_catid=
Or would something like that be cast aluminum?
However I know there are very small parts out there, that are machined and they are producing 10000's of them. I can't help to wonder what their production line would look like. 50 tiny mills with someone standing there changing work piece positions? I know a lot of these larger companies would have full automation and robotics, but there's plenty of small guys who are pumping out tons of product who wouldn't have the money for full automation machines.
Maybe i'm out in left field but i can't help to wonder.
djn
Old 07-21-2008, 04:42 AM
inflateable is on a distinguished road
Lots and lots of ways to do that. Machining tiny things is the opposite of me (I machine HUGE things - oil and gas parts and stuff) but looking at the pic, my guess is they're stamped out, probably in a couple of operations. Or you could cut from sheet (water jet or laser) and then finished. Or extruded and cut off to length. Or you load a lot of them onto a pallet and machine hundreds in one go on a full sized mill (very quick to to do in aluminium). Or die cast. Or sintered perhaps... I'd be interested what someone who makes small things thinks.
It pretty much depends on numbers as to the most cost effective way to do it.
Old 07-21-2008, 05:15 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
The photo in the link you posted, looks like cast aluminum. The reason I say that is, the parts surface looks pitted.
I would say that part was cast, then the holes drilled/chamfered.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 07-21-2008, 06:02 AM
Barry_ward's Avatar
Barry_ward is on a distinguished road
They are die cast
The part in the photo is die cast.
You can tell by the parting line on the part where the two mold halves seperate.
There is no second driling operation, the holes are molded-in.
2 of the holes are made with pins that are fixed to the mold core, and the 2 holes that are transverse, are made with pins that move inside the mold - those moving pins (generically called slides) retract after the metal is shot into the mold; allowing the part to be ejected after the mold opens.
It's also likely that the parts are made several at a time; on a "tree" (like plastic models) they can be hand seperated and manually de-burred (deflashed)(China) or put unto a punch press for the seperation from the sprue tree) The sprue and trimmings are re-melted, usually only seconds after being cast.
If the parts need precision boring or machining, they operation would be something like this:
  • Cast (maybe 6-12 or more on a tree)
  • punch press seperated and deflashed
  • tumbled
  • maybe plated, cleaned, dried
  • vibratory-bowl-fed and oriented to a cnc - lathe or mill, auto clamped and machined
  • washed and packed for shipping or next operation
The tooling and set up are not cheap - even in China - to make that part the quantities would have to be in the tens of thousands to make in economically. With a fast multi-axis cnc you might be able to make it for sub-a-buck. the same part die cast you can figure about $2-$4 USD per pound.
One more thing, that part might be "Zamac" Zinc-aluminum alloy. ("modern pot-metal" It's stronger (and heavier) than aluminum, and until last year cheaper on a per part basis.
If you want to make a million pieces, send me a PM.
Best regards,
Barry
my projects:
http://www.barryfish.com
Old 07-21-2008, 08:59 AM
joesz is on a distinguished road
If it is die cast it is one crappy die, surface finish is horrible so it probably did come from China, I would guess sand cast which is a whole lot cheaper, it would require secondary machining operations but with China using slave labor and prisoners, labor is not a factor. The only problem is if they are made in China they are more than likley garbage and either wont fit or will break after a few uses.
The products coming out of China are pure garbage and they don't care, they know most people will not bother to drive back to a store to return an item that only costs a few dollars so they flood the market with substandard garbage. Any one considering having parts of any kind made in China should reconsider, what good it is getting the parts cheap if they wont work or break after a few uses and don't forget it is a COMMUNIST country. A few years back trade with them would not have been allowed and it should be banned now. I would also ban any American company that moves its manufacturing over there from ever returning to this country. It is greed at the expense of American jobs and anyone that does it should be considered a traitor to this country and given the appropriate sentence that a traitor deserves, hanging by the neck. I Know way off base on this one it is just frustrating as an American manufacturer to see scumbags helping destroy our country to make a few bucks. If I ran this forum anyone helping to ship parts over seas would be banned from posting ,after all this is supposed to be an American site correct?
Old 07-21-2008, 09:20 AM
..and BREATHE.
Where does it say this is an american site? Any chinese manfs here?
Old 07-21-2008, 09:35 AM
Ok
The owner is quoting Ben Franklin so it was a wild guess that it was an American site. Free speech or not allowing Manufacturers or reps which I know there are some of those here the help to take American jobs away to line their pockets is a disgrace. As hobby machinists it may not affect you but as an American manufacturing company trying to keep American people employed it affects me and thousands of other people in this country.
It sickens me to see this happening and the people that are contributing to it, well guess what why don't you move to the third world country you are getting rich off of and live in the squander that those people live in for a while and see if you can still live with yourself knowing you are contributing to that.
As Americans it is time to stand up and voice your opinion, screw politicaly correct I don't care who it offends the facts are the facts and they are helping to destroy this country
Old 07-21-2008, 09:54 AM
So you don't believe in free markets? Or profit? Or Capitalisim? Or do you only believe in those things when you're the winner? Some socialist countries have factories run for the workers, on a not-for-profit basis, purely to provide jobs and support the community. Is that what you'd like? Lot to be said for that idea, but it's (shush) communisim.
I understand you're frustration, but surely you can't want a closed market for american manufacturers? Y'know, like Russia tried when they were communist? 'Cos that didn't work out too well.
Western manufactuers can't compete with china on cost, but they can on quality and customer service. The chinese work hard. We need to work smart and compete where we can.
That's that thread derailed then.
Oh, and I'm definitely not a hobbyist. An old fashioned apprenticeship, a degree in manufacturing and 12 years experience.
Old 07-21-2008, 10:28 AM
PinMan's Avatar
PinMan is on a distinguished road
Its unreal how quickly a thread can be hijacked by someone who wants to vent lol.
I agree with Barry, those parts are most likely molded as a finished product with a little bit of deburring.
And joesz, speaking as a formally educated and trained Machinist and CNC Programmer with 11 years of manufacturing experience, I have to agree with inflateable.
Whether you want to admit it or not, you are a hypocrit because I am 100% sure that you are supporting the very thing that you protest. You cant say that everything you use is 100% American made.
Old 07-21-2008, 11:03 AM
pin man as an owner of a machine shop for 23 years and with 35 years of experience as a tool and die maker with a journeymans card ,CNC programmer and Engineer and I will tell you that you have no idea what you are talking about. I buy American when ever possible even if it costs more, certain things you just have no choice because they are simply not made in the USA anymore thanks to cheap third world labor.
And to all you wannabe economic experts if you would like a list of the jobs lost in this country just from my area in the last few years then you can start to spout free trade.It is not free trade when you are being flooded with cheap products subsidised by a foreign government, that used to be illegal in this country. It is not free trade when they are allowed to export food, drugs and of all things kids toys that are killing people in this country. It is not free trade when they are not held to the same standards we are in environmental issues in basic human rights issues. How can you possibly defend this so called free trade how can you even call it free trade, do you even know what that means
As for quality being as good or better again you have no idea what you are talking about you must be watching too much TV how many of you have direct experiance with this, none? I am seeing products being brought back into this conuntry because of the garbage, poor deliveries and outright fraud by China, substituting materials or using substandard materials not matching specs. You can spout free trade all you want there is no such thing as free trade. Anyone that thinks this is helping the people of China .
watches too much Fox news they are being exploited and now that they are starting to see that the work is going to even more depressed places. I can tell you these are facts I deal with this on a daily basis so do not try to pit what you hear on TV against what I have direct experiance with.
I did hijack this thread and I am sorry for that some of you are blind and need to open your eyes, stop listening to what you hear on TV or read in the papers it does not reflect reality. I know I will get flamed for this but since I took this off track in the first place I wont post again. Let me say one final word any one of you that is for this unbalanced trade with China should move there and get the heck out of this country.
Inflateable your comments about capitalism and free markets for profit make no sense in this post you are so far out of touch that further discussion on the subject is pointless. When you have some real world experiance instead of what you see on TV then possibly you will be qualified to discuss this subject, until then you are only exposing your lack of knowledge
  #11   Ban this user!
Old 07-21-2008, 11:20 AM
Originally Posted by joesz View Post
...........If I ran this forum anyone helping to ship parts over seas would be banned from posting ,after all this is supposed to be an American site correct?
That was a nice rant.
Have you ever looked into how dependent US heavy manufacturing is dependent on exports, and how dependent the US is for imports of raw materials?
And why blame a manufacturer for wanting to make things cheaper? Nobody puts a gun to the customer's head forcing them to buy cheap low quality imports instead of more expensive quality made domestic products.
  #12   Ban this user!
Old 07-21-2008, 11:21 AM
I am talking from experience, believe it or not. I'm British, but I work for an american company, and we're taking work AWAY from chinese companies. We're taking work home from Indian companies. We even SUPPLY chinese companies.
How? We're faster, leaner, more accurate, have 100% customer service, zero scrap rate (<10ppm), zero customer returns. and in the long run, we're cheaper. Companies we supply go to Chinese companies, and six months later they're back. Why? Because we're better on all counts. We had a 20million dollar profit last year with 200people working here.
i.e. We compete.
I understand completley your point of view, honestly. We support local job shops as much as we can here, with tool and die work. But you can't buck the market, and you can't force people to buy from you. This is the reality, and you have to deal with it. If you can't compete, with respect, it's time to sell up.
DXF, PS, ESP, HPGL and more Company that manufactures Front Panels joe19 General CAD Discussion 0 06-17-2008 12:43 PM
RFQ Question (sort of) scratch_6057 Employment Opportunity 3 01-15-2007 04:14 PM
It's Alive!! (Sort of) Gashmore DIY-CNC Router Table Machines 3 06-22-2005 12:09 AM
What sort of software should I use. ynneb General CAM Discussion 2 04-12-2004 09:26 AM
What sort of router? ynneb DIY-CNC Router Table Machines 11 03-09-2004 02:08 AM
