Hi All, Well I've asked this question before and got links to the efunda site that has a table that is really confusing. I am trying to cut threads on my lathe, I am looking for what size of diameter to machine down to so I can thread a rod. Like I mentioned, I've seen some tables but it is rather confusing with all the different choices. Can someone give me a easy to read table or better yet let me know what they use for these standard sizes. Whats the magic formula for figuring this out? Thanks, skipper 6-32 8-32 10-32/24 1/4-20 5/16 3/8 1/2-13 |
| try this link http://www.engineersedge.com/screw_threads_chart.htm |
| In a book i bought it says that you basically can take the nominal diameter minus 1%.So with a 1/2 inch bolt which is 500 thousand you remove 5 thousand which would be .495 inch to start to thread..hope this helps
__________________ Andy |
| Also posted this in your other thread, Here's an online site with a chart showing thread per and such http://www.engineershandbook.com/Tab...readlimits.htm
__________________ Walking is highly over-rated |
| Thanks for the replys guys so, to answer my question from the tables (there are seven different column). Do I take the Max Major, subtract the Max Minor and is that the diameter needed? What is the Minor Diameter value that is given? thanks skipper |
| I may have mis-read your question. I was thinking that you needed the major diameter of the material before turning the threads. Are you wanting to know how much to dial in on a lathe to cut the threads to size? If so, are you using the compound slide at 30degree for in feed or are you plunging in with the cross slide?
| Here's a pdf with some general info: http://www.frappausa.com/PDF/Article...the/150235.pdf IIRC p = pitch p = 1 divided by # of threads in feed = p times .6 compound feed = p times .866 I couldn't find my notes from 1980 on threading. the old brain ain't as good as it used to be........
| Sounds like you are asking for the major thread diameters. These dimensions are for 2B threads, which are the norm. 6-32 .1372/.1312 8-32 .1631/.1571 10-32 .1891/.1831 10-24 .1890/.1818 1/4-20 .2489/.2408 5/16-18 .3113/.3026 5/16-24 .3114/.3042 3/8-16 .3737/.3643 3/8-24 .3739/.3667 1/2-13 .4985/.4876 1/2-20 .4987/.4906 HTHs |
| Need Help!- formula? | JOptionPane | CNC Machining Centers | 2 | 06-23-2008 02:52 PM |
| need a formula | gravy | General Metalwork Discussion | 4 | 03-29-2008 08:38 AM |
| looking for a Formula | rusticr6 | Haas Mills | 29 | 10-18-2007 11:23 AM |
| What is the Formula? | widgitmaster | General Metal Working Machines | 6 | 03-23-2006 11:35 PM |
| Formula | CNCRob | General CAM Discussion | 3 | 07-01-2005 10:18 AM |
