Results 1 to 7 of 7
Thread: Question about applying coolant
    Sep 2004
    After spraying coolant on the copper block im planning to mill, how do I drain the coolant? Or will it just evaporate? The mill im using doesn?t have anything for coolant..so I guess I have to do everything manual
    Sep 2004
    does any one have any experience with this?
    Aug 2003
    az
    When I had a Rong Fu I just drained the coolant through the coolant drain hole and into a bucket via a small hose. Applied the coolant through a small aquarium pump / bucket and loc-line type nozzle. You can drill and tap a little hole in the side of the table if you don't have one. If you don't have coolant channels in your table then you are going to have a mess on your hands no matter what you do.
    You could use one of those mist systems like triflo has, supposed to pretty much use up the coolant in the heat of the cut. You'll need a shop air supply for that I think.
    Moderator HuFlungDung's Avatar
    Mar 2003
    If your machine is small and easy to move, acquire some kind of a large drain pan to set the machine on. Even on a regular knee-type milling machine, the coolant trickles everywhere and wants to drip on the floor. What I did, was have a sheet metal shop make a pan for it, which I then sandwiched between the knee screw pillar and the base of the machine.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    I suppose it is obvious as well that a larger pan can be made and the whole machine can be set in it on the floor. I dont recomend this for smaller machines as the pan will get slippery and machine can walk around if being worked hard.
    Registered kenlambert's Avatar
    Jan 2004
    here is what i did .There is more pics on my sight ,on the smithy 3n1 i got an engine transmission tear down table from harbor freight for 89.00 and added a good set of wheels so i can move it around . Both machines have flood coolant and self contained no mess on the floor or anything
    Attached Thumbnails Attached Thumbnails Question about applying coolant-cnc_mill_cut2_004.jpg
    thanks Kenneth
    web-www.lambertsrc.com
    Learning CNC
    Sep 2004
    awsome...im gonna do just that except im gonna use some vinyl sheets and use a small computer water cooling pump ;D
    thx!
    1. Coolant eating my paint.
      By nervis1 in forum General Metal Working Machines
      Last Post: 12-05-2007, 04:27 PM
    2. How to avoid stinkin' coolant?
      By ESjaavik in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 10-10-2005, 07:47 PM
    3. Pics of my RF45 clone cnc conversion with flood coolant
      By CNCPlastic in forum Knee Vertical Mills
      Last Post: 01-26-2005, 03:02 PM
    4. Question on topping off coolant
      By CNCPlastic in forum General Metal Working Machines
      Last Post: 10-04-2004, 08:11 PM
    5. Coolant question
      By Dan B in forum General Metal Working Machines
      Last Post: 03-20-2004, 12:10 AM
