Old 07-16-2008, 12:15 PM
wheelgun is on a distinguished road
cutting threads
How do you cut a double lead thread on engine lathe.I have to cut a 4 pitch acme thread with double lead.
Old 07-16-2008, 12:41 PM
Your lead will be twice your pitch, i.e. 8
You cut one thread then move your tool along Z by the pitch and cut the other.
If you are familiar with the chasing dial depending on the lead on the leadscrew on the machine you can cut both thread by taking the cuts at opposite points on the chasing dial; this splits the lead.
Old 07-16-2008, 01:43 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Another method is to cut the 1st lead, then remove the drive gear and turn it 180 degrees and reinstall the gear.
if you are cutting between centers and using a driver dog with a face plate you can also index the driver dog to the opposite slot on the faceplate.
Geof's 1st suggestion is preferred.
www.integratedmechanical.ca
Old 07-16-2008, 02:58 PM
Thanks!
Cutting threads with sprectra light jjenks General CNC (Mill and Lathe) Control Software (NC) 1 01-27-2009 09:52 PM
cutting threads fourperf Haas Mills 4 03-04-2008 01:41 PM
Cutting threads on lathe... WilliamD General Metal Working Machines 2 11-21-2007 08:55 PM
Look at this code for cutting threads jjenks General CNC (Mill and Lathe) Control Software (NC) 0 10-25-2007 01:06 PM
Cutting Ext. Threads w/ Pro-Man Wildfire2 Fremonster PTC Pro/Manufacture 0 07-27-2005 12:50 PM
