Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Need a small hexegonal pocket for allen wrench?
    May 2007
    I need to cut a small square or hex pocket in the inside of a 9mm shaft, so the shaft can be held with an allen wrench.
    I do not have a fancy machine for this any good ideas? I have a mill and lathe.
    Thanks R
    Jul 2005
    One work around is to simply tap the end and use Loctite to lock in a socket head cap screw with a head less than 9 mm; 10-32 would be suitable.
    If the shaft is not hardened you can use and Allen key as a broach to make a shallow hex.
    You have to grind the end of a good quality Allen key perfectly flat to create a cutting edge.
    Drill a hole about midway in diameter between the across flat dimension of the key and the across corner dimension in the end of the shaft about 1-1/2 Allen sizes deep, and drill a hole the same size as the across corner dimension about 1/2 the Allen key size deep.
    Grip the shaft in the lathe chuck and the sharpened Allen key in a drill chuck in the tailstock.
    Use the tailstock to push the key into the hole to broach the hex.
    The larger hole acts as a guide hole making it easier to line things up.
    If it is too difficult to push it in a do the broaching make the small hole larger; making this larger reduces the amount of hex created and reduces the amount of torque that can be applied to the shaft with an Allen in the hex; there is a compromise here between what it is possible to make and how well it works.
    The Allen key of course will be tight in the hole it has broached so it is a good idea to use a pair of Imperial and Metric sizes that are close; use the large one for the broach and the other to turn the shaft. 7/32 is slightly larger than 5.5mm so that may be suitable for a 9mm shaft.
    May 2007
    "Use the tailstock to push the key into the hole to broach the hex." how hard do i need to push it, do I use a tool to do this?
    very interesting so the edge of a sharp allen wrench will actually cut the hole out?
    would a cheap arbor press be a better choice I need about 1/8" hex hole max in Stainless or mild steel. and not very deep. shaft is about 6 inch in length total. what ton capicity would you recomend if so.
    Jul 2005
    Quote Originally Posted by Rich05 View Post
    If you cannot push the key in just using the handwheel on the tailstock make the hole bigger.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    I broach them similar to Geof (why is it a am always following you up ol'boy and usually a half hour late).
    Only I grind the hex on an HSS blank (Allen key is not hard enough IMO) and I HOLLOW grind the end to produce a positive shearing action.
    I usually only drill a pilot hole the size of the flats for a small broach like that and the tailstock will easily push the broach in.
    As with all broaching operations use good quality cutting/tapping oil.
    www.integratedmechanical.ca
    Jul 2005
    Quote Originally Posted by DareBee View Post
    .... (Allen key is not hard enough IMO)....
    I guess really I should have said 'cold formed' not broach, broaching is a cutting operation and my way is more a squishing operation.
    Nov 2004
    us
    re: hex hole
    What size hex are your after? and what is the material of the shaft?
    Jan 2004
    Quote Originally Posted by Geof View Post
    Yeah
    I can see that.
    What I mentioned actually broaches, leaves little curls of material in the bottom just like some of the cheaper cap screws on the market.
    BTW don't forget to start with your hole, like 1/4" deeper than finished depth required.
    Jul 2005
    And I guess my way is more analogous to the high quality cap screws which are forged, all I lack is temperature.
    Maybe I am wrong though, are they hot forged or cold headed?
    Banned
    Jan 2006
    Seattle
    They're "hot headed"
    May 2007
    Quote Originally Posted by peter@slater View Post
    5/8" stainless steel rod with 1/8" allen wrench
    Jul 2005
    Your first post read; I need to cut a small square or hex pocket in the inside of a 9mm shaft, so the shaft can be held with an allen wrench.
    5/8" is a lot bigger than 9mm and makes the problem trivial.
    Get some 8-32 socket head stainless steel cap screws.
    Cut the heads off.
    Bore a hole slightly smaller than the head in the end of the shaft; if you look at the head you will see they are knurled and have a smooth ring, make the hole about the size of this ring.
    Push the head into the hole.
  • Page 1 of 2 12 LastLast
    1. A BETTER TAP WRENCH! SELF CENTERING!
      By northernmach in forum Product and Manufacturer Announcements
      Last Post: 08-28-2010, 02:13 PM
    2. Wrench machining
      By wildcat in forum Employment Opportunity
      Last Post: 09-19-2007, 06:15 PM
    3. Small 3D Pocket? help needed.
      By kprice1658 in forum General Metalwork Discussion
      Last Post: 09-07-2007, 11:47 PM
    4. X-3 Spindle wrench
      By DICKEYBIRD in forum Benchtop Machines
      Last Post: 12-26-2006, 06:20 PM
    5. anyone know what size spanner wrench?
      By jderou in forum Bridgeport and Hardinge Mills
      Last Post: 06-03-2005, 09:01 AM
