#14
You could also get a 1/8" hex rotary broach, #306-127($49). This will give you sharp corners. Usually you need a broach holder, but it sounds like you could just push it in for a few pieces. 'DareBee' was right, "don't forget to start with your hole, like 1/4" deeper than finished depth required." You will need some room in the bottom of the hole for the chip to curl into. They're in stock with most rotary broach suppliers. |
#15
| i've broached 1/4" hex into steel a bit. spot drill for a pretty chamfer, drill just under the flats of the id hex, undercut with a key cutter so you dont have that ugly mess at the bottom, endmill to size, and broach with a hex. we use ground hexes. we also drill a thru hole to help the air escape. |
#16
| There are tool to do this with you know ![]() But the allen key works just fine, you could even drill the hole a little larger than the allen key are on the flats. I have the tool to do this on large series, its like a coned allankey in HSS and its out of senter but its angled too so that the allan like HSS tap hits the senter anyway. I usaly rut the tool at 250 to 400 rpm i mild steel. (ST52-3) If its just one or two parts I would go for the allan key tric |
| A BETTER TAP WRENCH! SELF CENTERING! | northernmach | Product Announcements & Manufacturer News | 19 | 08-28-2010 01:13 PM |
| Wrench machining | wildcat | Employment Opportunity | 4 | 09-19-2007 05:15 PM |
| Small 3D Pocket? help needed. | kprice1658 | General Metalwork Discussion | 6 | 09-07-2007 10:47 PM |
| X-3 Spindle wrench | DICKEYBIRD | Benchtop Machines | 3 | 12-26-2006 05:20 PM |
| anyone know what size spanner wrench? | jderou | Bridgeport and Hardinge Mills | 3 | 06-03-2005 08:01 AM |
