Old 07-10-2008, 10:48 AM
Rich05 is on a distinguished road
Converting a Grizzley Lathe to CNC is it worth it?
Is it worth having a CNC lathe, and is it worth converting a grizzley? What cost I expect. What are the benifits of such a conversion?
I have a 3 axis CNC mill could not imagine running that without the CNC.
R.
Old 07-11-2008, 07:17 AM
blackbeard52 is on a distinguished road
convert to cnc
I think you have answered your own question... If you do repetitive machining even the simplest. it is worth it. cost will vary greatly depending on the drivers,controller, and drive methods you use (servo vs. steppers)(gecko vs. uhu)
It really comes down to needs.
Old 07-11-2008, 11:51 AM
roger that thanks. I can expect $4,000 outlay for a nice conversion, been told.
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 04:27 AM
New Machine Build- Milltronics mill- converting to verticle lathe dmelacom Vertical Mill, Lathe Project Log 1 03-10-2008 07:05 AM
Converting manual lathe to CNC pwpeterson General Metal Working Machines 4 11-22-2007 11:26 AM
Converting a lathe to CNC Odie Wan General Metal Working Machines 1 04-18-2007 10:37 PM
I found an old logan 850 lathe for 100 bucks is it worth it? trilect General Metal Working Machines 4 06-29-2005 05:52 PM
