Old 07-08-2008, 04:52 PM
Bryan GD is on a distinguished road
Aluminium Drilling - Small Bit
Hi everyone,
I am attempting to drill a 1.8mm diameter hole into aluminium. However, I find that the drill bits I'm using just keep on breaking. I am very inexperienced when it comes to machine work. I was told to use a quick spiral type drill bit (which I am using, think it was called that). Does any PLEASE have advice on technique, drilling speed, lubricant, drill bit type, etc.. cause these drill bits breaking all the time are beginning to be a pain in the butt. Thanks a lot.
Cheers
Old 07-08-2008, 04:54 PM
Oh and the hole is about 6mm deep
Old 07-08-2008, 07:50 PM
Med-Pac is on a distinguished road
What are you using to drill your holes?
Old 07-08-2008, 08:13 PM
guru is on a distinguished road
1.8 or about .070" dia. going thru 1/4" plate is not a difficult job
chuck those hi-spiral drill bit in the collet , try 2800-3000rpm, feed at F5.0 ipm, peck every.050" -.062" and flood with soluble oil. Spot drill first to keep drill going straight not binding in the holes.
Old 07-08-2008, 08:29 PM
Grade of alum. might be an issue also. 3003 and 5052 like to gum up the bit, 6061 is probably best for machining, 7075 is harder to drill and machine.
Old 07-08-2008, 11:34 PM
tikka308 is on a distinguished road
I agree with Guru, although depending on the rigidity of the mill, 5IPM might be fast for the Z feed. I use a TAIG (small benchtop CNC mill) and usually drill closer to 2 IPM. Like guru said, spot drilling first, pecking the drilled hole, and coolant are all crucial.
Tormach PCNC 1100, SprutCAM, Alibre CAD
Old 07-09-2008, 12:45 PM
Thanks guys, things went a bit better today (pun not intended).
I forgot to mention one important thing: I'm not using a drill press, but a hand drill, which obviously makes it more difficult to keep the drill vertical when drilling.
Old 07-09-2008, 12:48 PM
Bryan: I would avoid using a hand drill at all costs if you want to avoid problems when using small bits! Even with large bits, you're precision will be mediocre at best.
Old 07-13-2008, 02:39 PM
Thanks tikka. I'm drilling into the one end of a 1000mm Al extrusion, and am having trouble setting the extrusion up so I can use the drill press. Unfortunatey I am working in a rather limited workshop. Seems like I might have to drill a lot more of these, so maybe it'll be best I take another look at using the drill press.
Cheers for now.
Old 07-13-2008, 07:16 PM
recordist is on a distinguished road
Reducing Drill Breakage
Also, if you weren't already, keep the length of the drill as short as possible.
  #11   Ban this user!
Old 07-13-2008, 07:53 PM
metalworkz's Avatar
metalworkz is on a distinguished road
You should be able to turn the drill press table out of the way and perhaps use an angle plate etc. as a guide. There are also drill guides that attach to a hand drill that I have implemented and found to be very usefull when using a portable hand drill to keep all the drilled holes perpendicular to the drilled surface. They are generally made from aluminum or zinc and are fairly light and manueverable compared to using something like a mag-drill. The hand drill-guide may be less favorable for drilling the ends of things as you probably have little surface to rest the base on, but even this can be worked around if needed by mounting the tube between 2 angle plates etc. You probably have already worked this out by the time I am posting, and I hope you have found and easy workaround.
Regards,
Wes
  #12   Ban this user!
Old 07-13-2008, 11:34 PM
Cory is on a distinguished road
I find 6061 to be much worse than 7075. 6061 is rather gummy as well. 7075 cuts much nicer IMO.
Drilling/boring aluminium in the lathe kong General Metalwork Discussion 8 06-09-2010 09:45 AM
Drilling very small holes William Demuth CNCzone Club House 7 12-21-2008 04:56 PM
deep drilling small holes in aluminum Fremont Dave General Metalwork Discussion 13 11-25-2007 02:03 AM
Low runout, small hole drilling rpawluc General Metal Working Machines 0 01-01-2007 06:23 PM
small hole drilling & tapping dneisler General Metalwork Discussion 6 02-10-2006 09:54 AM
