Old 07-08-2008, 12:35 PM
themez is on a distinguished road
Problem with pigtail lead on custom thread
The thread is a M5 x.8 . custom thread ...The thread lead starts at .080 diameter and then transitions to .150 minor diameter of the thread. The problem is the .08 transition to .150. I can send iges, we use Mastercam Any cnc lathe guys out there.
thanks,
Old 07-08-2008, 01:41 PM
Does your machine have the ability to do G32 threading?
This threading cycle allows the taper, and lead, to vary anywhere along the thread.
Old 07-08-2008, 03:23 PM
heres a pdf of the thread. notice the start. disregard the cuts in the thread.
I am interested in the start of the thread. I do have a file wihout the cuts.
Old 07-08-2008, 04:33 PM
Old 07-08-2008, 04:51 PM
I think that is simple if you have G32; I have never had any need to use it but I have seen pictures of threads that had a point similar to that and then a straight portion.
Old 07-08-2008, 06:27 PM
g-codeguy is on a distinguished road
Yup, use G32, pullout & return in a subprogram, modifiy the start position.
double lead thread johnmckeown Haas Lathes 3 12-04-2007 10:49 AM
Turning a custom thread w/G33? SRT Mike General Metalwork Discussion 3 10-31-2007 11:42 PM
retaining thread lead argomch G-Code Programing 2 09-24-2007 07:22 AM
Multi Lead Thread phoodieman Mastercam 1 04-06-2007 11:38 PM
How many thread starts in your lead screw? widgitmaster Polls 13 02-20-2007 01:08 PM
