Old 07-07-2008, 05:47 PM
artin51 is on a distinguished road
Boring Head
Hello everyone,
Just want to get people's opinion on using a boring head to get a hole to size. I'm looking into pulling the trigger on a boring head kit from iscar and would like to know of any issues people have had. Obviously the machine spindle has to be in good condition and the work rigid. Can i expect to get holes with to within +/-.00025" on the diameter? Assuming normal usage conditions?
thx
Old 07-07-2008, 07:45 PM
laka is on a distinguished road
Depending on the number of holes you need to bore, repeatability of the desired size may be a problem. If you have spindle air-blow during tool change this will help a lot. I've had boring heads cut large/small from having dirt/small chips on the taper and thowing it out a little.
On our machine with spindle air-blow we run our sandvik boring heads all day and they will stay within +/- 0.0005 for sure. Make sure you rough the hole out with an endmill before boring, leaving the same amount of stock on every hole so you dont have to worry about deflection too much. On holes up to 1" we usually leave 0.002 to 0.004" on diameter to bore. Over 1" maybe 0.005" to 0.008", we have good luck using wiper inserts to get good finishes.
Good luck
Old 07-07-2008, 10:19 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I think .00025 is pushing it a bit for a boring head. It is possible but not so realistic.
Half thou would be usual expected tolerance.
If you wish to get fussier than that you really should go to jig grinding.
www.integratedmechanical.ca
Old 07-07-2008, 11:36 PM
I thought +/-0.00025" is half a thou.
Old 07-08-2008, 01:45 AM
KyleH2's Avatar
KyleH2 is on a distinguished road
No that would be a quarter thou.
.001/2 = .0005
.001/4 = .00025
Anyone know where I can get a 4" boring head? Also it needs to go on an MT2 taper 1/2HP Bridgeport, is that too small for that big of a boring head? I need to bore a 3.5" hole.
Old 07-08-2008, 09:36 AM
.001/2 = .0005
.001/4 = .00025
If I have a nominal size that is permitted to vary +0.00025 and -0.00025 the difference between the largest permissible size and the smallest permissible size is 0.00025 + 0.00025 which is 0.0005.
Old 07-08-2008, 12:32 PM
DareBee's Avatar
You know what I mean Geof.
Yes Kyle that is too big.
Also, if you intend to do milling with a MT taper please wear a baseball glove and be prepared to use it at any given moment.
Old 07-08-2008, 12:59 PM
hoidahl's Avatar
hoidahl is on a distinguished road
Iscar Boring Head
We use the iscar ITS bore heads. They are very accurate and we have held +/- .00025 but we hand loaded the tool each time and had small quantity of parts.
Old 07-08-2008, 01:37 PM
KyleH2's Avatar
I am not positive its an MT2 as it is not my machine nor have I spent any time playing with it. Its a little 1/2 HP baby Bridgeport, I think a BRM. If it is they came in Morse 2, B&S #7 and Standard B-3(never even heard of this one :P). I am just assuming (yes I know what happens) its MT2. That would be convenient because you can actually get boring heads and collet chucks for MT2 spindles easily and cheaply. Right now all he has are collets.
Old 07-08-2008, 02:06 PM
thx
Thanks for the reply guys. I'll go ahead and purchase the kit. For your information the iscar kit that does .24 to 1.13in diameters with the CAT40 adaptor was quoted to me around 2000$. At the moment we send the parts to get honed, so i'm trying to bring the process in house.
  #11   Ban this user!
Old 07-10-2008, 12:20 AM
juergenwt is on a distinguished road
+/- 0.00025 not a chance. Save your money. Juergenwt.
  #12   Ban this user!
Old 07-10-2008, 01:43 AM
Palerider is on a distinguished road
Save the boring for last, dial it in, and don't remove the holder between parts.
If tool wear isn't a big issue or lack of material homogenosity it should be right there every time.
Which small boring head for Seig X2? Claven2 Benchtop Machines 5 03-21-2008 01:20 PM
What Boring head should I go with for CNC? SchurrPower General Metalwork Discussion 4 03-10-2008 06:07 PM
Making a boring head rigo430 Metal Working Tooling 6 09-20-2007 11:08 AM
Boring Head tips required! digits Benchtop Machines 12 06-15-2007 03:14 PM
What size boring head should I buy? Kevin Harpham Metal Working Tooling 2 02-09-2007 05:55 PM
