Results 1 to 5 of 5
Thread: HDPE
    Mar 2004
    HDPE
    I milled some HDPE plate/sheet yesterday and was quite impressed at how easily it milled. At my 1500rpm max, I found that 5 ipm left a slightly frayed edge, but that went away at 10 ipm. 15 ipm was very clean as well. All of these at 0.05" doc, with a 1/8" EM btw.
    So how would I do a 0.2" doc slow finishing pass with this? I expect I'd get the fraying if I ran slower.
    Jul 2005
    Was it a new tool or had it already done some milling on metal?
    With a new tool you should not get any fraying at any feed.
    Mar 2004
    The endmill was used previously for acrylic, but it's relatively new still. I have a couple new ones that I can try/compare.
    Registered fatal-exception's Avatar
    Mar 2006
    HDPE dosen't fray in my experience. UHMW does...it's easy to confuse them since virgin UHMW looks alot like HDPE.
    You could probably take the entire .2" on a single pass with an 1/8" end mill unless it puts too much lifting stress on the work piece.
    I usually leave between .01 and .02" for a finishing pass. 100ipm@4000rpm. Leaves a nice smooth surface.
    Paul
    Mar 2004
    This is definitely HDPE -- at least, that's what I purchased from McMaster. But strangely enough, I've been reading the horror stories of painting HDPE, and I seemed to have no problem with regular spray paint, no primer, but a bit of sanding. I doubt it'd durable, but I don't need it to be as this is an aesthetic part.
    On my mill I've found (for aluminum) that because of my 1500rpm limitation, a nice slow 1 ipm pass taking 10-thou off gives a nice finish. And I'm anologizing for HDPE. I'll experiment a bit more.
    1. Delrin or HDPE, which did you use?
      By Glidergider in forum DIY CNC Router Table Machines
      Last Post: 07-22-2010, 09:14 PM
    2. HDPE acme nut
      By Rickv100 in forum DIY CNC Router Table Machines
      Last Post: 06-25-2008, 01:48 PM
    3. Engraving HDPE
      By Nick1983 in forum General Metalwork Discussion
      Last Post: 04-25-2008, 04:16 PM
    4. HDPE Bearings
      By jhowelb in forum Linear and Rotary Motion
      Last Post: 03-04-2008, 03:45 PM
    5. Best Supplier for HDPE?
      By dshowalt in forum Glass, Plastic and Stone
      Last Post: 08-19-2007, 10:52 AM
