| I use ER16 and ER32 collets all the time for drills, they get a much tighter and more accurate grip than drill chucks.
| Agreed with Geof.........collets are much more rigid and more accurate in term of drills running true but drill chucks are much cheaper than collets, if you running conventional machine drill chuck may be a way to go, but if you running CNC then go with collets, those cheaper double angle collets will work just fine for drilling operation. |
| With R8 your drill shank must be the same size as the collet, R8 has no over- or undersize capacity. On large drills, 1/2" and above, drilling into steel, sometimes it is best to put a spacer inside the collet behind the drill shank. The prevents the drill pushing back in the collet, but make sure the spacer is a slightly smaller diameter than the drill.
| You can get very cheap made-in-china R8 collet chucks that use ER32, ER16 or ER40 collets on eBay if you are just drilling holes and them being perfectly round isn't a big deal. You can also get nice ones from MSC. |
I use CT-40, ER-32, ER-16, and drill chucks. My drill chuck was like $200, my ER-32's $180 or so, and ER-16's $140? |
| Kress Collet/Chuck Problem | djh82uk | Benchtop Machines | 9 | 10-08-2011 05:15 AM |
| Need Help!- collet chuck onto rotary table | ptxman | Work Fixtures and Hold-Down Solutions | 4 | 09-15-2008 01:35 PM |
| Air collet chuck for a c3? | gazmalman | Mini Lathe | 0 | 06-15-2008 07:23 PM |
| Chuck Drill Chuck Alignment | TomV | Mini Lathe | 5 | 04-27-2006 02:20 AM |
| Which collet chuck? | Al_The_Man | General Metal Working Machines | 3 | 06-27-2004 02:11 AM |
