| good flood coolant found. I tried mobil sol oil, rotted in a couple weeks even with a skimmer and bubbler(dear God what a mess that was to clean out), hangsterfer, same story started out strong but after a couple months it got the rot, rustlick powerchip worked great no rot but.... ate my paint. I've been using synthetic lubricants inc. "universal plus" for a month or so. It's a full synthetic, rust protection, doesn't eat my paint, no smell, no rot, seems to work great. Oh and it's biodegradeable, non flamable, non-toxic and costs 71 bucks for a 5 gallon pail from KBC, thats 40$ cheaper than Hangsterfer. Thought I'd pass it along to anyone looking to try a new lube / coolant. |
| I have been useing auqa 600 fron grizzley 30.00 a gallon but a gallon will last me almost a year
__________________ thanks Kenneth web-www.lambertsrc.com Learning CNC |
Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Yep, it's a water mix 20-30:1. |
| I had emailed them about the ratio before you replied Dave, actually their recommendation is even better. The ratio for the Universal product depends on the process you are running. The general range of all metalworking fluids are from 5-1 (5 parts water to 1 part coolant) to 30-1. The 5-1 could be used for heavy machining operations, but I would recommend using a 10-1 for machining. If you are grinding, I would recommend using a 25-1 dilution as you will need more cooling than lubricating, water being the coolant. If you have more questions please call me at 1-800-848-5823 My name is Tony Thank you for choosing Synthetic Lubricants Inc for your lubricant needs. |
| Well that's what I get for asking the KBC rep. I'm really happy with this stuff it works great, still looks brand new. I was soooo sick of cleaning that coolant tank out. What a messy PITA, especially with oil based coolant. Hopefully I won't have to empty that thing for a while. |
| I am going to give it a go myself, say, aren't you supposed to be out in the garage making cool stuff? |
| I got something planned for this weekend, a little redesign of the AR reciever, made it a little more blocky looking, and added some slots through the sides of the mag well bay just for looks. |
| I run Syn-Lube GM from the same guys, before going with it, I talked to the fluid designer for about an hour. Nice guy, great fluid.
__________________ Aaron Moss www.IndustrialHobbies.com |
#10
| ooh, okey, im gonna try it too, just to make sure, itll work fine with copper correct? and i have to mix it with water before using it... thx! |
#11
| Well I just wanna say I'm not trying to sell the stuff, just wanted to pass along something that I found worked as advertised. I'm in the same boat as a lot of you I think in that without someone here to hold my hand I just try this and that untill I stumble upon something that works. It's a really good feeling when I finally get it right. This stuff is still fresh after two months in the AZ heat in my garage getting used only on the weekends. Another nice thing about syn lube over the sol-oil stuff is that I can see the part while it is being cut. I can also see the bottom of my sump, makes knowing when to clean it a bit more than guess work, like it used to be. In terms of coolant care I also added a coalescer, and ditched the wheel skimmer. Works much better, keeps the coolant moving 24 / 7, and full of oxygen. |
#12
| I still use the old cutwell 45 from Esso, does any of you, and are you still happy?? Well...think I'm ready for a change, I'm not too happy anymore, I feel the oil is just not the same anymore, or maybe it's just me? What I feel like lately, the oil gets "bad" early, the water separates, and it looks like I have clear water coming after a few weeks and things are starting to rost! Is there a good substitute, for the same price?? Konrad |
| Coolant eating my paint. | nervis1 | General Metal Working Machines | 5 | 12-05-2007 04:27 PM |
| Flood coolant on steroids | Scott_bob | Machine Problems, Solutions , Wireless DNC, serial port | 7 | 04-30-2007 02:07 PM |
| How to avoid stinkin' coolant? | ESjaavik | Machine Problems, Solutions , Wireless DNC, serial port | 28 | 10-10-2005 07:47 PM |
| Building my shop, Found out that I'm not a good estimator. | trilect | CNCzone Club House | 26 | 05-15-2005 10:17 PM |
| Pics of my RF45 clone cnc conversion with flood coolant | CNCPlastic | Knee Vertical Mills | 9 | 01-26-2005 03:02 PM |
