Old 06-22-2008, 12:30 PM
Rich05 is on a distinguished road
Removing steel with corncob rougher?
I have IH mill 3 hp, with 3250 rpm, and flood coolant; need a good tool to hog out some mild steel flat 4 flute HSS endmill still very slow. Is there a better tool 6 flute?, high helix?, how about using a rougher? thanks
Old 06-24-2008, 01:48 AM
gsrmmeza is on a distinguished road
What size roughing endmill?
Are you slotting or profiling?
Coated or uncoated?
6 flute Roughers are usually larger the 1 inch.
Make sure you get fine pitch not the coarse.
They cut better.
Old 06-24-2008, 05:59 AM
Karl_T's Avatar
Karl_T is on a distinguished road
A rougher is a good choice.
If you'd like to go to a whole nuther level, take a look at Sandvik R390 insert cutters. I normally run them dry, thermal shock is huge issue. They are designed to put the heat in the chip - they come off black and will burn you if you get in the way.
Karl
Old 06-25-2008, 12:15 PM
msomerville is on a distinguished road
Why don't you give a carbide fine tooth rougher a try? You can get a 3/4 tialn coated for about $80.
Removing Tooling Mooser General Metal Working Machines 9 03-07-2008 09:16 AM
Wave cut rougher? kesparate General Metal Working Machines 3 11-16-2007 02:47 PM
Removing a Gecko sploo Gecko Drives 4 12-11-2006 05:51 PM
Removing nut off ballscrew, I've never seen anything like it geohot Linear and Rotary Motion 7 12-23-2005 10:53 PM
Removing the armature ? Ken_Shea Servo Drives 3 10-10-2005 03:40 PM
