Old 09-12-2004, 04:34 PM
replicapro is on a distinguished road
What type of end mill is used for plastic?
I want to cut acrylic sheet, and I was wondering if there is a special end mill for doing this so the edges of the plastic stay smooth and dont need to be polished after the cut.
Old 09-12-2004, 05:17 PM
ger21's Avatar
Onsrud makes bits for plastics. http://www.onsrud.com/index.html
Vortex also has some. http://www.vortextool.com
If you want a polished edge, you'll probably have to polich it, but it is possible to get a very smooth edge. The above tooling is generally for routers, btw.
Old 09-22-2004, 04:22 AM
BT1 BT1 is offline
BT1 is on a distinguished road
slot drill...
Old 10-16-2004, 01:02 PM
Kmed is on a distinguished road
WHat spindles speed / material thicknees / cutter diameter.
Machine ridgidity will have a marked effect of the surface appearance as well. You can see what you cant feel.
2 flute straight cutters 3/8 or 1/2" I have had excelent results at 15-20 k spindle speeds, air blast and 100-200 ipm feeds. So acrylics are harder or softer which will also affect the cut IE cast / extruded sheet.
To get a perfect edge a diamond cutter will works best, and a diamond edger will give you the best machined finish.
Hope that helps.
Old 10-18-2004, 07:24 AM
E-Stop is on a distinguished road
Depending on the application, I have used router bits and Dremel bits. The Dremel bits work well in a variety of materials and they are inexpensive.
Old 10-18-2004, 08:47 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Most plastics manufactures recomend using router type cutters.
Old 07-17-2010, 04:20 AM
gleas's Avatar
gleas is on a distinguished road
If you have the rpm's, (6000+) Onsrud up spiral router bits are very good for edge finish. Plastic generally requires much more rake on the cutter, and the router bits fill that gap.
-Greg
"If Necessity is the Mother of Invention, then Who's the Father?"
Old 07-17-2010, 04:47 AM
neilw20's Avatar
neilw20 is on a distinguished road
Cutter direction.
I have found that conventional milling works better because the rubbing action burnishes the surface and helps to stop the cutter eating the chips.
Use plenty of air to keep the chips clear.
If there are many parts to do, cutter wear can become significant, so I use solid carbide.
The coated cutters will give a better finish but are much more expensive, and they appear to have a more finely ground finish.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 07-18-2010, 12:28 AM
eaglezsoar's Avatar
Gold Member
eaglezsoar is on a distinguished road
Onsrud 63-515 1/8" O-flute. 13,000 RPM at 120 ipm feedrate with 0.06" depth per pass. Not inexpensive but one of the best for all plastics.
Light travels faster than sound. That’s why people appear bright until you hear them speak.
Old 07-20-2010, 09:26 PM
SRT Mike is on a distinguished road
I tried every Onsrud cutter they recommended and they worked like *crap*.
I followed their recommendations to a T, tried changing my cutting conditions and never got them to work worth a damn.
I do not cut very thin stuff, nor do I do routing (although I cut parts out of acrylic on my VMC).
In my experience, HSS seems to give a better finish than carbide. I was told HSS cutters hold a sharper edge. I have a piece of 1/2" acrylic block on my desk right now, I cut it out with a 1/2" eight flute finishing cutter (this one is carbide). The finish is not crystal clear, but it's damn close. It's a 1/2" thick block, 2" x 2" square. If I hold it up against my computer screen edge on (I cut out 4 sides), I can read text through it no problem - so it's pretty damn clear.
That was around 30ipm, full depth, 1/4" on the width, shoulder cut, 6000rpm with coolant. Coolant makes ALL the difference. I 3D profile acrylic all day long - without coolant it's hazy with coolant I get a very clear (almost crystalline) finish.
  #11   Ban this user!
Old 07-21-2010, 11:29 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Acrylic? I cut lots of that with HSS two flute end mills- lets the chips get out. Air mist coolant- again to get the chips out.
One note: Cast acrylic machines much better than extruded. I won't machine anything acrylic unless it's cast.
You can smear the part with soap if you don't have air mist (thanks Geof)
Hope this helps.
I love deadlines- I like the whooshing sound they make as they fly by.
G-Code to DXF WayneHill OpenSource Software 189 01-30-2012 11:15 AM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 02:24 PM
Ball end mill help foamcutter General Metalwork Discussion 4 07-21-2010 01:59 PM
Pro/manufacture -number of decimal places arc events dsergison Post Processor Files 4 05-27-2005 01:50 PM
What type of end mill do I need? jderou General Metalwork Discussion 12 09-03-2004 03:59 PM
